Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 225 Guests are viewing this topic.
Magluvin
One more thing..
Sorry Carrol for putting up what you said as an example of what Im stressing for accurate replications. If we think as professionals on these things, then we should all be on board with trying to replicate to the best of our abilities to get the best base line as possible if we are going to really investigate these things seriously. People use to analyze and dissect videos to find clues as to if a claim was faked. Like  there was this crazy guy Mylo that was claiming he had a Howard Johnson motor going and made vid after vid. Tk would point out the mr hand movements off camera that he did to keep the rotor going while aiming the camera at another portion of the device as diversion. Then the guy did other vids on glass dining room tables and shows getting up on the table and walking over it to try to prove there were no 'strings' attached, whatever.
Some viewers looked into the vids like it was CSI and found the fishing line loop going to the motor under the couch cushion that was driving the rotor. But we dont see that level of investigation these days. If we are serious about all this, and we should be, then we should be very detail oriented and not trying to idealize what is happening or what we think may be a better idea before we produce as best a replication as possible and study that first as a base line. Like the depictions show 1 battery. Then why change it to 2 in series?? There is no good reason to make any changes of what we can see of the build. Like we could look at some of the items in the photos that we can use as a reference as to size of things that we have no data on. People used to do that in the Whipmag days. I dont see that anymore.
So Id like to see everyone that gets involved to put those kind of efforts into these replication projects so there can be a straight up conclusion in the end. We are putting our selves up as judge and jury with this stuff. I think free energy is a serious enough thing that we should look at it as if the claimers life is on the line in order to get to the honest truth. Otherwise if the investigation is tainted or handled with initial bias, then the end results may not be felt as conclusive.
And what you said in the other thread about resonance. I get what you mean. Like I could just say that we get some advantages to the LC ringdown. But that ring down frequency is called what?  Would it be called its resonant freq?  I think so. Speakers have Fs or some call it Fo and it is the resonant freq of the speaker itself. Or reed switches, they have a resonant freq spec also, something that you want to stay away from in typical use for switching. So Ill change how I talk about that subject when it is not just a constant resonant reaction to a constant input or signal, like the speaker boxs are. ;) But I still think there are advantages to the ringing one way or the other.
Mags
Jeg
Hi guys :
If stator coil is an open-circuit while magnet is approaching and so there is no any opposition, rotor gains some energy just only from the fact that magnet is attracted from the iron core. It is some kind of magnetic energy transformation to kinetic. So to my innocent eye, looks like that if coil is activated from the moment that magnet is aligned with it, up to a certain "critical" moment, then after this point attraction again will equalize the loss in kinetic due to Lenz which takes place when coil is "on".
At least one of the effects that could take place in there. ::)
Grumage
Quote from: Jeg on November 15, 2017, 02:40:06 PM
Hi guys :
Hi Jeg.
Now you're talking!!
So, what would happen if we have the capacitor across the coil? Would its charging affect the operation of your statement above? Or do we close the switch onto the capacitor and coil at the maximum?
Cheers Graham.
Jeg
Hi Graham :)
It will be charged as normally, but needs to be discharged before loosing its charges if it is not to use diodes.
(i erase that as wrong assumption)
regards
Jeg
Tuning the cap/coil to magnet revolutions per second seems to be to our advantage.
