Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
This schematic of then Adams motor shows how basic the wiring is; Simply a diode and capacitor in parallel with the battery:
synchro1
Here's a picture of my half finished four magnet rotor:
synchro1
Robert Adams produced a formula for coil dimension coupled with a strength test for his rotor magnet. Placing a magnet behind the masking coil core would require more weight in coil copper to generate an eqivilent magnetic strength. This would require a larger dimension coil.
The advantage to increasing attraction strength this way is that the additional strength comes at no increased cost to input power. The commutator and circuit would remain nearly identical to Adams' motor.
This novel motor is a "GAP Adams".
synchro1
Here's a picture of the finished four magnet rotor: The 1/1/8" Radio Shack ceramic rings are a perfect fit for the 1-3/8" PVC fixtures.
synchro1
Here's an excellent window Adams motor configuration video. The output coils are built and positioned to generate "Lenz Acceleration". The D.C. fan generator may accelerate the rotor regenerativly under load the same way.
My "GAP Adams" uses the Art Porter commutator not the single contact of Robert Adams. The backspike cancels the re-gauging output and needs to be side tracked.
https://www.youtube.com/watch?v=GflQEMrS5Fk
