Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Here's a video of the attraction rotor generating power in the masking coil:
https://youtu.be/s-Yw4QstSHU
synchro1
Here's the D.C. fan commutator with the first "Latching Reed Switch" attached and blinking an LED:
https://youtu.be/z76vwiVP3zk
The tiny Neo magnet fragment on the razor blade was not glued well enough and detaches toward the end of the video. Very simple to fix for good. It really works fine.
synchro1
Here's a video of the 500 newton electro magnet masking 6 ceramic block magnets controlled by the "Latching Reed Switch" commutator:
https://www.youtube.com/watch?v=0KSGNseHga4
synchro1
This single 1.5 volt Reed switch loop pulse motor can power the D.C fan commutator with practically zero input, and also generate power:
https://www.youtube.com/watch?v=vWvI7T7h3tk
synchro1
Here's a video of the commutator with two reciprocating "Latching Reed Switches": I wired two LEDE's to them, and they light one, then the other in sequence very nicely. I also installed an output coil under the 500 newton EM for the oscillator magnet piston.
https://www.youtube.com/watch?v=isA9JCe8mnc
