Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
This video makes the difference between a steel and magnet solenoid core clear:
https://www.youtube.com/watch?v=om0yTP59nG4
synchro1
lever.
https://www.youtube.com/watch?v=4H7Cn4MxTss
crank shaft.
https://www.youtube.com/watch?v=ACLwD0WZlsU
Any work that crankshaft does is free power! The oscillator recovers it's own power pulse.
Belfior
if the oscillator recovers it's own power pulse then start that thing with a cap that has energy for just one pulse. It will run forever right? Put a watt meter before the transformer and do measurements when the crank shaft rotates freely and when it actually turns something. If the measurement is the same for both cases you just revealed something about levers that has been hidden for thousands of years!
A lever does not multiple energy
http://wtamu.edu/~cbaird/sq/2013/07/02/how-do-levers-create-energy-if-the-conservation-of-energy-does-not-allow-energy-to-be-created/
Belfior
if you want to do something mechanical then design a magnet motor with coils & caps. That might actually work.
Otherwise it is just a waste of time in my opinion. Why would you want friction, gravity and air drag (plus god knows what else) that eats everything you gain?
synchro1
Quote from: Belfior on October 12, 2018, 08:11:43 PM
the output voltage is 5x's too high for that slick a switcheroo.
