The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
sm0ky2
18.2(X10^-31)x(300(x10^6)^2x1.6(x10^-19) =5.1^5Coulombs
That is what is released in the collision
forest
STOP
unless you want another thread with 10000 posts !
All you want to do is use your capacitor to produce magnetic field.
This is the begin of journey
AlienGrey
Quote from: citfta on December 19, 2017, 09:13:36 PM
AG,
My post was based on over 50 years of experience with caps.  I retired from a career of working in electronics.  There are no "plates" in a normal capacitor.  There are layers of foil wrapped around each other with the dielectric material in between.  When I was a kid my dad had a TV repair shop.  He would let us have the bad condensers as they were called then.  They were coated in wax.  We peeled that wax off and unrolled the foil across the yard.  So I know first hand what they are.  And the rest of your post doesn't appear to have anything to do with what I posted.
Smokey2,
You can't have it both ways.  You're claiming the spark gap will limit the voltage and I agree.  But Tajarek is claiming he can go over voltage to charge the cap faster.  You can't go over voltage if the spark gap is limiting the voltage.  So I still maintain that you will blow some caps and possibly be injured if you insist on trying to charge them with over voltage.  I have seen what they do when they explode.
And the comments about me from Void are entirely correct.  I am actively searching for OU because I have seen enough to convince me it may very well be possible.  But I also try to correct mistaken ideas when I see them.  I don't want people wasting their time on false ideas.  Now if a person is doing research and experimenting to try and learn that is a great thing to do.  But when a person claims to have solved OU and they haven't even built anything yet to demonstrate their claims then I am very skeptical.
Thank you Void for your kind comments.
Respectfully,
Carroll
Wax capacitors  sure Ive seen them when a kid and the older folk use to slung them out the old radio that looked like church doors from the 20s  ;D or an old Phillco  radio from the 50s but lets get more up to date on the plates thing they are used in led acid battery's, E V Gray used his spark tube to regulate and dissipate surplus energy while charging a battery by boiling a small section of acid known as de-sulphating at the same time a capacitor is i different kettle of fish oil  ;D but where is the formula for this kind of work (out of the window). All this Tesla stuff was around  in the 1920s none of it is new just different materials. But what is so called free in the free energy malarkey you asked and i say to you look at the Townsend electron avalanche principle it's a fact you will be luck to find any formula for or teachings on yet exists, even if some like to get up set over on these pages or threads, and they do  ;D ;D ;D ;D ;D ;D ;D
As a youth I can remember asking a college lecturer about Tesla work his reply was it's more than my jobs worth to devote time on that kind of material with a huge grin on his face!
Allen
blueplanet
This one is another example of laughing stock which could illustrate the point:
https://en.wikipedia.org/wiki/Oxford_Electric_Bell
This bell has been ringing for more than a century. Based on the ball movement, the power output should be around 0.2mW. To make things simple, I am not going to consider the power of ringing sounds and the heat as a result of collision.
The voltage column of the drypile is about 1200volts. This yields a current of 0.16 microamp. I seriously doubt if it has any measurable current at all.
However, the ball moves more violently when the humidity is low. Lower humidity means higher resistance, which in turns is equivalent to a lower current. Lower current means lower power output. This power output probably has little to do with the dynamic of the ball movement.
AlienGrey
Quote from: blueplanet on December 20, 2017, 06:23:35 AM
was it worth the floor space, seen it before thought it was a wast of space then.
Allen
