170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
seaad
Quote from: cheors on March 28, 2018, 04:42:44 PM
J'ai identifié la position des LEDS bleues
I identified the position of the blue LEDs
This is important: Pierres repetition frequency of all (blue LED) steps IS about 5 HZ !!
Ceci est important: la fréquence de répétition Pierres de toutes les étapes (LED bleue) est d'environ 5 Hz!
shylo
It's like binary code, the more coils you have the more back spikes you can collect.
One coil gives you 2 points of collection, Two coils give you 6 points of collection.
The more points of collection you add ,the smaller they get, but the sum of points is greater than the lesser amount.
Also the faster you switch ,the greater the collection.
I still think there is lenz but maybe not, or maybe not as prominent , not sure?
Just what I'm testing right now, These are only my thoughts and where I'm looking, maybe it'l lead somewhere.
artv
T-1000
To ensure if that is correct - https://filebin.net/a59twe0yqzthkgy7/100_free_energy_generator139v_1600watt___DZ_generator__part_4-slowmo.mp4
Hopefully Pierre will not have objections about few seconds clip cut.
And pictures from explanation video:
https://i.imgur.com/hpDXFv4.png
https://i.imgur.com/CwrNJVB.png
https://i.imgur.com/NkNCryA.png
Cheers!
r2fpl
I see not work (LED) 3-8 relays ? LED broken ?
Did anyone make a diagram LEDs blue to RED (relays)?
seaad
This is important: Pierres Output frequency IS about 15 HZ !!
NOT 60 Hz !!
Ceci est important: La fréquence de sortie de Pierres est d'environ 15 Hz!
PAS 60 Hz !!
http://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/msg518827/#msg518827
Quote; ""Some here think a replication is based around the physical properties of a device,when they should base it around working principles of the device.
Brad ""
