170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
oscar
Hi Pierre,
thanks for re-plublishing your 4 videos on your channel
Hi all,
attached is an animated gif of  Pierre's switching sequence as I understand it
I started out drawing the small static image at the bottom of this posting showing 36 coils, with 1 set of 6 coils energized (the coloured lines),
- red and blue symbolizing magnetic N and S
- the numbers in the image symbolize the 36 slots
- the depicted coils are "wound"  according to Pierre's magic numbers as proven true by r2fpl
Quote from: pmgr on March 31, 2018, 11:41:18 PM
...a coil span of 6 slots ...
01-06 07-12 13-18 19-24 25-30 31-36
02-07 08-13 14-19 20-25 26-31 32-01
03-08 09-14 15-20 21-26 27-32 33-02
04-09 10-15 16-21 22-27 28-33 34-03
05-10 11-16 17-22 23-28 29-34 35-04
06-11 12-17 18-23 24-29 30-35 36-05
I note that his one has his magic number sequence 01-06 ; 02-07; 03-08, etc. see post #170.
the animation is meant to show two coil sets (each consisting of 6 coils) energized overlapping in time, to not interrupt the field, as per Pierre's advice.
The transmission was a '53 (Johnny Cash)
r2fpl
oscar,
excellent animation  :D
It is possible that power on allways 36 coils but only 6 changes off.
Pierre could also do that and talk about 6 not on but off.
T-1000
Quote from: oscar on April 02, 2018, 06:27:44 AM
When watching Pierre's 1st video https://www.youtube.com/watch?v=B7BZeeJmvjY in slow motion you will notice there are 7 LEDs activated at the end of 6 relay switch activation cycle. Not sure why 7 as there is 3 phase being rotated..
Also if you flip from one coil into neighboring second without having middle point activated it will cause spikes and nowhere near smooth transition from one to another.
r2fpl
Quote from: T-1000 on April 02, 2018, 07:42:02 AM
No 7,  8 !  see 1 relay frame by frame.
1 relay, position (corner) left bottom.
There is more dependence here than we think.
T-1000
Quote from: r2fpl on April 02, 2018, 07:56:12 AM
Well, apparently there is middle transition as I suspected. 12 relays have delayed active state for while 9 new LEDs are lit on arduino board.
