user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 18 Guests are viewing this topic.
CTG Labs
If you look closely in the video, you can see Marco is using an transmission line arranged for LMD, where the magnetic and electric components are IN PHASE contra to the norm.
Perhaps Sparkman can tell us why?
Its time for some real comments and stop all this bitching, like a bunch of women at a mothers meeting.
D.
turbo
Quote from: allcanadian on December 11, 2006, 01:08:32 PM
Ok I'll take a swing!
The bird on a wire taken literally is a tank circuit shown as A,B, or C the avremenko plug- Im guessing B. In the picture the label "PD" indicates the Potential Difference or voltage travelling along a wire and how it relates to the birds feet. As you can see, the lower bird will intercept a larger PD and fry, barbeque. So your HV coil sends a sharp spike down the line, the birds feet placement as a time function of the primary frequency determines the PD in the bird as a whole. And if the bird was resonant with the primary frequency you would have useful power as a pumped mass in the bird but it would not use power persay as you are not pumping mass(charge) in the primary to any extent, it would only produce a small phase change in the primary.
The question is primary power? Do you use a spark gap to isolate the primary circuit in resonance with many "birds feet" secondary circuits?
I would do as tesla would have, make the primary a tank circuit, the HV coil and Cap form this with many "birds feet" secondaries. One of the secondaries again as a time function of the primary is tapped back to the primary coil input with some type of regulation device to limit max voltage. Preferably a step down transformer, parallel cap and voltage regulator Im guessing.
Am I even close here?
hi allcanadian , :)
Yes , it looks verry much like it,
exept for i use no spark gap, no voltage regulators.
and my bird isn't sitting on the line no more it's between lines.
before this setup indeed i was into the avremenko plug with strong diodes this was when i noticed the negative potential.
Turbo.
allcanadian
Hello Turbo
After I posted I realized I don't like any of the secondaries here is a better one I think.
roggy32
This is pure BS, I can take a 1.5 volt NiMH battery and hook it into what is basically a stepping power supply and power anything for a short amount of time. SM took 60 of those non-rechargeable batteries and directly powered stuff bypassing his stepping power supply later on. A battery will supply as much current as you ask before it burns out, there is no limiter except for the leads burning out.
I take my 1.5 volts and put a 555 timer on it and pulse it to 8-9khz, now I can use very very small step-up transformers only requiring one turn of wire as the primary and as many on the secondary as needed for the voltage needed. 10 turn secondary means 1.5 x 10 volts = 15 volts.. the tesla coil and the tesla transmitter means it's now in the thousands of volts at 8-9k frequency. Yes, I can power that bulb for a very short time. Spend about 400 bucks and buy 60 or so of those NIMH watch batteries and tape them together and you have a 100volt 1.5 or so amp battery pack that can power things for about 30 minutes or so, but totally unrechargeable.
hartiberlin
Quote from: sparkman on December 11, 2006, 12:52:20 PM
In response to post 85 from Marco
As a matter of fact, yes Mr. Marco, especially when that someone has been as misleading, cryptic and fraudulent as you have been.
You prop yourself on paper mache pillars and act too important for your britches.
And you lead people to spend good money on worthless baby Tesla coil kits that brag of free energy. This money can be better spent on their children.
Grow up Mr. Marco, and learn how to debate your opponent skillfully or give up and climb back into your hole.
Your beard has been pulled off! Neophyte!
Please Sparkman,
just accept, although you have been director of Research and Developemt
for 30 years with probably too much money spent into the wrong directions,
that you did not achive in 30 years with your 15 engineers,
what Marco has achived now in a few weeks of time!
Please don?t be this rude to him and quit to hit on him !
Marco has really achieved something now, that just needs
to be researched in a serious manner and
does not need to be ridiculed or hammered on !
Please behave as the Pro you quoted yourself to be !
Many thanks for your cooperation.
Marco, please continue with your research and keep
us updated with your next steps.
Many thanks Marco, for sharing this all with us !
Have a nice evening.
Regards, Stefan.(admin)
