ltseung888
Actually, I was somewhat surprised that the first 10,000 posts did not raise the replacing of the pendulum with an Unbalanced Wheel.  The many implementations or replications of the Milkovic 2SO focused on large mass and large size.
The most important factor in Centrifugal Force is the angular velocity or rotational speed.
Many QMOGENs got it right.  Use motor to increase the rotational speed.
The best is still the Tsinghua University Energy Multiplier - motor to drive Unbalanced Cylinders...
Lawrence
see reply 2826
MarkE
That still produce no external work, thus doing nothing for the input energy, thus being underunity.
ltseung888
Received email from Taiwan Edison to see if I want to be a distributor of Maglev.
Looks like the Maglev is real.  The first thing to do is to check it out.  It may be time to get the young and capable involved.
At least one QMOGEN is available for investigation.
Void
Quote from: ltseung888 on March 11, 2015, 02:25:59 PM
Many QMOGENs explicitly use Flywheels.  For the garage inventors, the chance of producing a slightly Unbalanced Flywheel is very high.  Dr. Raymond Ting replaced his flywheel with an explicit unbalanced flywheel.  (Bolting a hammer to a flywheel).  The resulting torque twisted the shaft.  The device shook so much that he had to stop the experiment.
Hi Lawrence. The large flywheel in the video may well be from a commercial source such as a flywheel designed
for some industrial machinery. Also, it seems highly doubtful to me that a small imbalance in a flywheel
would cause the device to be over unity. If there was any significant imbalance in the flywheel then the
flywheel would likely cause very noticeable shaking in the frame. Sorry, but you appear to be really reaching to try to
justify your ideas, but the fact is if at least some 'QMogens' which do not use any unbalanced wheels or unbalanced
cylinders really do work as claimed, then it is simply not known (at least publicly) what is causing them to work.
All the best...
MarkE
Quote from: ltseung888 on March 12, 2015, 07:32:21 AM
Why don't you publish that letter after blacking out any personal details about yourself?
