Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
jerdee
Thank you for your help Pierre, looking forward to the translation from LUC.
Everyone, listen to the MP3 file attached.
  I was able to do forensic audio on the YT vids and extract the timing pattern.
This was pitched down considerably and slowed down to hear the pattern clearly.
You will hear immediately the pattern that was placed in the original code.  Pierre has been very honest! Two HIGH's at the beginning of 12 and TWO lows at the end of 12 pulses.
Each clack of the audio is a HIGH in the repeating pulsings of relays in the code.  His code is correct!
1-High
2-High
    low
3-High
    low
4-High
   low
5-High
   low
6-High
   low
7-High
   low
8-High
   low
9-High
   low
10-High
   low
11-High
   low
12-High
   low
   low
Just wanted everyone to know that this is the pattern, and there is no confusion on this. This was meant to be in the code !!!
Jerdee
jerdee
Why have we not thought of utilzing both a 36 and the 30 pole in normal generator cycles?
It is very clear that Pierre is using overlap of the code to push the magnetic field from set to another set of coils.  He is also reversing the coils!
I believe the CODE pins are not suppose to line up with coil numbers in succession. The code is correct, its the connection to the coils.  The HUGE clue is the TWO HIGH's and the TWO LOW in the code.  LEARN the cycle of a generator.
We have to think about another way to connect the code pins to the correct arrangement of coils.  Luc is only using 1/2 of his bridges and diode recovery.  I REPEAT HE IS ONLY USING HALF BRIDGES.  The coils need to be flipped just like a normal generator!!!  This is why we are getting a very weak field and very little output.
Maybe this gif will help you all to think about a three phase system.  THINK THINK THINK!
Look at the gif.
JerDee
[size=78%]https://solidstateelectricgenerator.files.wordpress.com/2014/12/syncron-generator.gif[/size]
pmgr
Quote from: pedro1 on April 18, 2018, 08:40:55 PM
bonsoir a tous ,
j'ai regarder les progret que vous fesiez sur le site de overunity et naturelement j'ai vue l'exellent travail de luc et de sont superbe appareil qu'il a réussi a faire tourner un champ magnétique et il semble être sur la bonne voie mais il va toujour vous manquer quelque chose et je ne voit pas grand monde penser a ces points crutiaux vous êtes trop concentrer a faire une réplique de mon prototype les bobines,3pole ,6pole le nombre de transistor etc
je voit que personne ne sait jamais poser  la vrai question de comment peut-on faire du courant  et qu'est ce qui se passe en décomposant le cycle d'une génératrice ,si vous comprener vraiment cela  par la suite vous serez en mesure de mieux comprendre le principe du dz générateur et vous n'aurez plus besoin d'essayer de copier le dz générateur qui est loin d'être parfait il y a beaucoup de chose a améliorer sur cette version
-permièrement ,que se passe t-il quand l'on approche une aimant d'une bobine il y a une variation du champ magnétique et plus l'on approche de la bobine collectrice il y a un champ d'opposition qui se crée donc une variation et l'intensité de cette aimant a une grande importance
donc VARIATION ET INTENSITÉ sont les mots a retenir
-deuxièmement ,quand la vitesse de déplacement de ce champ magnétique est passer rapidement plus grande seras la fluctuation sauf quand c'est une bobine électro-aimant il faut prendre note qu'il y a unTEMPS DE CHARGE  de la bobine et si le champ magnétique  est déplacé trop rapidement avant que la charge soit completement charger vous aurez une perte a ce niveau en plus de la perte du retour de bobine .
-troisiement ,le MOUVEMENT  de ce champ magnétique que vous avez commencer a expérimenter donc vous commencer a comprendre
-et  finalement il y a les RETOUR DE BOBINE si vous les canaliser au bon endroit et au bon moment vous aurez un alier très puissant et non seulement un destructeur de mosfet  cela s'avère un partenaire très intéressant a utiliser
bien sure il y a des pertes dans les bobines et dans la resistance  etc, mais si l'on compare le dz générateur a une génératrice avec un moteur a combustion qui a des perte de friction de chaleur et l'électro-aimant du rotor que l'on doit alimenter  l'on doit frôler le 70% ou plus  de perte cela ne se compare pas au dz générateur au quelle j'ai éliminer la plus grosse perte c'est a dire le moteur a combustion  ,dans mon premier prototype j'ai fait des erreurs de conception
dans la bobine je croit que le fait de croiser les champs peuvent nuire a la performance c'est pour cela que j'ai changer ma méthode dans mon second prototype il y a surment plusieurs façon de concevoir un dz générateur je vient de vous fournir tout les ingrédient pour faire un tel apareil il suffit de faire votre propre recette  avec les 4 point que je vous ait donner et il est très probable  que vous obtiendrez un overunity il y a juste a mettre le bon dosage au bon endroit j'espère que vous prendrez note de ce message car c'est le secret du dz générateur ce sont les 4 point qui on été mentionner plus haut  si un de ces points n'est pas dans le montage que vous faite vous n'aurez jamais un surplus d'énergie j'espère que mon commentaire vous seras utile pour la suite et je ne traduirai pas ce message je vais laisser une autre personne faire la traduction car il parait que google traduction n'est pas très bon pour avoir une bonne traduction bonne soirée la dessus .
        pierre cotnoir
Thank you Pierre for the explanation.
This is my take on his four points:
1. He mentions the CHANGE of a magnetic field (which is achieved by rotating the magnetic poles at a frequency f by the Arduino) and he talks about the change in the STRENGTH of the magnetic field itself (which is achieved by the change in current through the coils). The largest current change occurs for the coils that are shorted for a short time during the Arduino overlap; before the overlap, the current through this coil is e.g. positive, during the overlap the current is constant, then after the overlap it reverses direction and becomes negative). So it changes from a positive current to a negative current (large dI/dt), so on top of the rotating magnetic field, there is an additional change in magnetic field due to the change in current direction. As a side note: generated voltage at output coil (and for BEMF) V=-dflux/dt where flux=L*I (inductance*current), so V=-(I*dL/dt+L*dI/dt), first term is caused by the spinning magnetic field (also called parametric variation), second term is caused by change of current (caused by switching of current direction).
2. He talks about how fast the magnetic field changes which is proportional to the frequency at which the field spins around (frequency f). So the faster you spin the field the larger the generated voltage. However he mentions the TIME CONSTANT (load speed) of a coil. The highest frequency a coil can respond to is f=R/(2*pi*L). He says that if you spin the field too fast, you will get a loss trying to charge coil and thus also in the return of the coil. In order to get the highest possible frequency, there is a trade-off between R and L. R is proportional to the number of windings, L is proportional to N^2 (square of N), so frequency is proportional to 1/N. So if you want a large frequency, you can't make too many windings per coil.
3. He talks about the MOVEMENT of the magnetic field here which is done by the Arduino and he says that is we need to study that first. This is why I suggested Luc go back to the small magnet and play with the Arduino code and speed it up and down to see where the TIME CONSTANT (load speed) of his coils are. For Luc's coils, inductance is about L=2mH and R=0.5ohms, so highest frequency possible is about 40Hz. This might explain why he has no output at 50Hz as the coils can't respond fast enough. Typical safety factor is a factor of 2 below the f_max, so keep the spin speed at 20Hz or below.
4. Lastly he talks about the RETURN OF THE COIL (output coil) which will be reflected back to each of the six coil sets. He says that if you collect them at the right spot (coil) and at the right point in time, it will provide useful energy instead of destroying your mosfet. He says this is the most important point. In my understanding, this will also explain why his device is not dependent on load. Actually, the more load he puts on, the higher the collected current will be.
PmgR
d3x0r
bonsoir a tous ,
        pierre cotnoir
How do you accomplish variance using digital relays?
pmgr
Quote from: d3x0r on April 18, 2018, 10:05:50 PM
I believe this is achieved during the overlap time of the Arduino when a coil is shorted, see my post above. The current in that particular coil will change direction, e.g. from +1 to -1 in a very short period of time (determined by L/R time of coil).
PmgR
