0 Members and 73 Guests are viewing this topic.
citfta
Quote from: d3x0r on May 04, 2018, 04:45:25 AM
You have a bad connect on the lower left switch.
Also, you have 4 relays between the coils on the end (two to the left of the first, and two to the right of last) not 100% why that's causing the oscillation, since it should be just the same as having the first closed; which it already is...
@any
Any advice where to source AC motor/generator cores?  Was considering getting a alternator from the junk yard, but they don't have very much metal on the outside for the outer flux path.
Here are a few links to places to look for surplus motors:
https://www.surpluscenter.com/
https://www.blowerwheel.com/electric-motors
http://www.skycraftsurplus.com/dcmotors.aspx
r2fpl
@any
Who said it could not be different? Pierre did not say everything. Most important thing is joining the stator. There are many options.
T-1000
d3x0r
Quote from: citfta on May 04, 2018, 05:58:07 AM
There's a Granger down the road... https://www.grainger.com/content/general-catalog  but kinda silly to get a new motor...
I also thought maybe AC (air cond) repair places? (like the blower fan motor but tthat's < 1HP)
Quote from: r2fpl on May 04, 2018, 08:32:24 AM
Ya; but when attempting at replication I prefer to try to match paramters as close as possible; since I don't have anything else immediately available that's viable...
I have  a bunch of E cores, which I can sort-of use; but they are very small; so using 24ga wire it's really low inductance; and 32 ga wire is much better inductance; but with 12V doesn't really generate a good field (too much resistance); so I don't those will be viable... plus too many wedge-shaped gaps inbetween...
also considering the null results vs what I have seen of other replicators; that might be a factor;
also I don't know if the slots are important; such that a ferrite filled coil set should also have the fingers?
