T-1000
Quote from: r2fpl on May 04, 2018, 01:08:23 PM
So according to Figuera ?
As you mentioned, he did same as Pierre with making magnetic field move without moving electromagnet by kinetic force. But while keeping magnetic field always active, switching coil sets to make magnetic poles peaks/ neutral/ reverse move across pickup.
seaad
Quote from: d3x0r on May 04, 2018, 11:03:20 AM
I have  a bunch of E cores, which I can sort-of use; but they are very small
also considering the null results vs what I have seen of other replicators; that might be a factor;
also I don't know if the slots are important; such that a ferrite filled coil set should also have the fingers?
Here is the principle of my new small test bed. A double straight line, the Figuera way. Ferrite E-cores (small) in rows after each other and side by side on top of two bigger Ferrite U-cores. The output is on a single or a double I-cores. See my princip pic.
Regards Arne
r2fpl
seaad
Quote from: r2fpl on May 05, 2018, 04:10:04 AM
It seems that the meter itself gets voltage at the moment of the sequence.
https://youtu.be/xrxhqFsXNSE
Yes.
Reply #480 on: April 16, 2018:   http://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/msg519967/#msg519967
" It is strange that Pierres digital voltmeter COMES ON and lits  BEFORE the main 5 Hz Arduino sequence starts ???
3:rd film 10.0 min. "
Maybe that meter only needs a few Volts to work/ lit?
Regards Arne
r2fpl
Quote from: seaad on May 05, 2018, 05:13:36 AM
Yes.
Regards Arne
I did not remember you wrote it, sorry.
Yes, a few volts but is very important for answer how this work.
I think this is a magnetic field spin in opposition. This is my version for today :)
How make this effect after this start sequential. I must make this work.
