Jeg
Quote from: T-1000 on June 03, 2018, 09:36:30 AM
When coils are like in Pierre's contraption they are facing about 20 degrees off the pickup coil core. In your photo they are on 90 degrees.
That is true, but i am not going to use a fixed rotor coil as Pierre did. I will use some of the 36 coils as a secondary. :)
gotoluc
pmgr
pedro1
Vraiment impressionnant!!  il y a beaucoup de progrès depuis ton premier essai et a tu réussi a le pousser un peut plus ou C'est a venir n'oublie pas que plus tu injecteras du courant plus que tu devrais avoir de meilleur performance tu pourras tordre le champ de façon plus efficace n'oublie pas que j'ai alimenter mes bobine avec 26volt et je voulait me rendre à 48volt mais je croit que tu devrait commencer à avoir des résultats intéressant a 20volts
En,
Really impressive !! there's a lot of progress since your first try and you have managed to push it a little more and I guess more to come.
Don't forget, the more current you inject the better the performance and you will be able to twist the field in a more effective way.
Don't forget my coil input was 26volt and I would of preferred to go to 48volt but I think you should start to see interesting results at 20volts
gotoluc
Quote from: pmgr on June 03, 2018, 02:15:13 PM
AWESOME!!
Here is another video demo focused on the coil return (collapsing field & collecting diodes) which many have been wondering how much power is actually returned from the coils discharges.
I can confirm at the low frequency Pierre was working at, it looks to be less then 10%. So if the diodes return is a big part of the effect we are not getting much from our low inductance 35 turns coils at low frequencies. However, the higher the frequency the more efficient and around 400Hz the scopes (in vs out) current probes measure the coil return to be about 80% of the input power but the output is much less.
Link to video: https://youtu.be/IaWbGIsAT14
