IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
"... The CIP engine is not a new energy source,but a tested and proven method of converting Coriolis and centrifugal forces into linear thrust . ...",
CIP = Cook Inertial Propulsion   http://www.rexresearch.com/cookip/cookip.htm
I studied the net-info about Cooks device in the End 90' and compared with Otto Steins "Die Zukunft der Technik"-engine !
http://www.rexresearch.com/cookip/cookip.htm#uareport
During this segment of the cycle the propellant is stopped at the expense of the forward momentum of the cart.
https://www.yumpu.com/de/document/view/20184764/otto-stein-die-zukunft-der-technik-pdf
                                       acceleration and stop -  cycle
Thrust :  weight/specific weight
Propulsion/PWM
nix85
I knew of CIP for years, here is the principle, never liked it, overly complicated and apparently not so efficient.
I do like tho how he solved the issue to change the direction the weight oscillates elegantly simply using additional rotation along it's axis. How is the weight captured by the arm not exactly sure, looks too complicated and probably wouldn't work well at higher rpm.
https://www.youtube.com/watch?v=48Ri_HjLWR4
What Cook shows in this diagram is the same thing i am showing. It's always the same principle.
nix85
Eh the blindness. Again
ANY UNBALANCED MASS
1. OSCILLATING WITHIN 180° OR LESS
2. OR SPINNING FULL CIRCLE WITH VARYING SPEED
CONVERTS CENTRIFUGAL FORCE INTO
LINEAR ACCELERATION OF THE WHOLE SYSTEM
nix85
Quote from: Jerry Volland on March 28, 2021, 01:53:48 PM
Anything which is perpendicular to the plane of a rotational system is external to that system's rotation.
There is nothing external here. Completely sealed system can accelerate in space by simply oscillating a pendulum within 90° on the inside.
It is interacting with the spatial energy, not displacing matter or acting against "external" forces.
