Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
ramset
I think this is a great test protocol to advance your Findings.
IMO very good advice and easy enuff to do , there are probably plenty of fellows in that group in NZ who would love to help with the testing .
I never had much success with the Drawings,[feeling stuff ?] But I absolutely believe Aether 22 is getting results in this area ,good control's are important
also we do have other members in NZ...
Chet
Thanks Grandma
aether22
Quote from: Acca on July 25, 2018, 02:47:21 PM
As you are fascinating bringing up these effects of the aether,  like to here more on the effects, like on the helix wound  "smith coils"..
Acca..
Sure, well just to clarify, the type of aetheric energy that I have found most readily abundant and most readily related to coils and electronics is, well the first functional coil I made was a coil made of a coil (wire coiled around wire) just as a Torus coil is like a single turn coil made of a coil.
But the point is the energy is of a spiral nature, that is because I presume electrons are literally spinning, the it is this spin energy, this right handed spiral that is the energy I tap with some/most experiments.
This is the energy that easily transfers from one wire with a simple twist, hence the reason for the twist in the ends of the first coil above.
But the nails in that story were bent into a spiral shapes, which kinda makes sense if the energy is amped up to insane levels.
I have found another energy moves in the other direction with a left handed spin, this seems from all experiments to be a positive charge, and they are even attracted to each other like charged particles, and I have found that these 2 energies collide, this collision stirs up more energy in a potentially runaway reaction just as SM described!
Also, this positive energy, too much you get sick as it shuts down the flow in your DNA, I have experienced this by making coils wrong, it is not pleasant.
Actually, I say the coil I made around 2012 was the first coil I felt energy from, actually that is not quite true, I first made the mirror image of it in 2001, it was wound in a left handed fashion, and hence pulls in and circulates the proton energy which is less abundant.  I thought I could "kinda maybe" feel the energy, but there is less proton energy (possible due to it being on the inside of the atom) and so I really wasn't sure, it was at the edge of sensation, it was too subtle and because i wound that coil the wrong way I lost 11 years of progress!
Acca
S.M coils are very interesting as to the nature of spin of the generated magnetic field in those coils will keep the magnetic field inside.. Round doughnuts coils like the ones that have angular slope have a vortex type of spin.
As the velocity of the "superfluidic" hyper- space is super-rigid that has spin, the effects are opposition to directional change which requires energy and it induces friction in matter. My studies suggest that aether is rigid super fine vortextial "material" that interacts with matter on a sub-atomic level... and these helical vortextial stuff is the cause of the effect as what you have listed some of these effects..
Aether is the cause of straight travel in space (inertia)  and NO directional change, as if to change direction aether is opposing mass in the directional change. More mass the object carries more energy in needed to change the direction.
So science is at loss to explain the absence of "that aether".  Permanent magnets have spin and will increase in velocity if dropped from high elevation and decrease depending which way you can configure them.
All types of spin will effect the aether, try this next time you get out of a chair , as you get up rotate your body keep your legs together it takes less effort now try different spin direction..
Spin interacts with mass and gravity has no effect spin just aether..
I hope to provide you with a mechanical device that is altered by aether spin "real world" , like the Skinner weight
power amplifier from 70 years ago... Also that Earth is moving through space 66,000 mph. frame dragging it at a velocity of 19.5 miles per second.. Not earth rotation speed.. Aether is flowing through everything..and you.. move your arm back and forth,  it's inertia..that you feel..
Acca.
aether22
Acca, I agree to the extent I understood.
But let me ask you this, with your model of understanding of aether, do you have any ideas of how to affect it?
Ways to tap it?
I ask because a lot of ideas can simply be drawn or made with wire and the truth can be revealed as i am sensitive enough to tell what's going on even if the effect is modest.
I know of many ways, but sometimes I am limited by my imagination, there are things I simply don't think to try.
Other things I try because of some idea, it works but not for the reason I initially tried it.
There are a lot of powerful ways to engineer the aether that are very simple, effortless.
aether22
Maybe it is the result of arguing with too many internet trolls...
Some of which I believe are paid (operation mockingbird)...
Some of it is a distaste for skeptics like "The Amazing Randi" who is a charlatan IMO.
Really I don't like these so-called skeptics, I say so-called because true skepticism is also skeptical about their own biases against believing something.
Also, I don't want to be on the radar of those looking to suppress this kind of research.
Plus there is the consciousness factor which I explained.
So while I am sure we can find someone that can suit us both, maybe a member of this group in New Zealand (I live in Tokoroa BTW, but could if need be travel).
Or maybe someone from the local polytechnic...  or maybe a local very mild skeptic, well, really more of a seeker.
Just someone who will make sure the test is conducted well, but not anyone who is going to really care if it does work, I think a lot of skeptics are in denial and will never accept results.
Whoever it is could consult with skeptics and you on how to conduct the test with all due Rigor, leaving as little doubt as possible about the result.
But please remember, I want most of all to fly under the radar of those who seek to squash stuff, I am only presenting this in this forum because I expect to be lumped into the crystals and orgonite and energy healing crowd, not that that isn't somewhat accurate I guess...
I don't actually want any white papers to hit academia, I don't want to go public till I can fly my Anti-G saucer over a sports game and land on the field, or at the very least have a Free Energy generator anyone can build.
As for the money, I can afford to lose it, yes a donation sounds fine.
To be clear, what we would be testing is your assertion that you can yourself detect the subtle energy (or whatever you like to name it) emanating from your diagrams. This is a first pass at a basic test. If you yourself cannot reliably detect which box contains your diagram, then there is something wrong with your claim. Either there is no energy to be detected, or you cannot detect it, or the box blocks detection somehow, or some combination of these factors. Further, more refined testing would tease out the finer facts. If on the other hand you _can_ reliably detect the location of the concealed diagram, then you have a start of something really big -- if further testing confirms the results of this preliminary test.
Well a printed image with no light won't work well (it works more with the light than the ink).   It would require either a light in the box or the image be on a tablet computer (which I don't own any suitable example of)
A coil for that reason might be better.
Some of the energy from images is actually blocked by opaque objects, the energy from an image actually re-creates the form of the design in space in-front of the image as though it were a projector.
This seems to be dependent on an energy that is optical because the design is.  But secondary energy dynamics projected from a design are not generally stopped by opaque materials.
So I will have to in such an event do my own testing, interestingly I don't really NEED a device to feel the energy from, once you have a lot of energy built up in your body, you both run it through objects, and you become more sensitive to energy, so it is not hard for me to potentially pull off that magicians trick of the nail in the paper bag, but I would elect against slamming my hand on the bags I think are empty as that is un-necessary.
Another option is there could be a bag, and I run my hand along and mark where along the length of it the coil/object is.
My request if I pass is not that you publish a white paper on this, but rather that you simply take seriously what I have to offer and try experimenting with it.
