Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
aether22
Quote from: icarus on July 30, 2018, 09:10:36 AM
The new wire around the inner coil:
In this way ? With knotted wires terminals like in your pics ?
No, that coil was meant to be wound around a single thin wire and not the rest of the coil.
Here, this makes it clear, the wire transitions from grey to copper coloured in the image but that is just for contrast purposes, in reality all of the wire would be copper.
icarus
Hi Aether22,
I rewound the inner wire (external side) with another wire; the outer coil asymmetrically (one side more turns than the other).
I tested it with a battery and then with a frequency generator from a few hz to a few mhz, square wave: nothing, I do not feel anything, nada, nichts, rien.
Maybe I'm still wrong, but I think some more information and details on the dimensions, measurements and specifications of the device would help.
Thanx
conradelektro
I can feel it!
Just tried the the "feel v3" image on my big PC screen.
MY HAIR IS STICKING OUT !
How can I get rid of this phenomenon? Be careful incase you have longer hair than me !
Greetings, Conrad
onepower
Aether22
On a note of interest concerning your two cup experiment. The probability of your first guess was of course 50% however 10 correct choices was 0.009% and 15 correct choices falls to 0.0003%. The probability that anyone could randomly make 15 correct choices is effectively zero.
It would appear you have proven most peoples opinion to be incorrect.
aether22
Quote from: icarus on July 31, 2018, 08:26:26 AM
Hi Aether22,
Thanx
I am not clear on if it is not correct, but I would suggest strongly for feeling purposes you wind that coil on the lead wire, I uploaded an image to spell it out, this should make the other end very suitable for feeling energy from.
I will also today or tomorrow wind the coil as I intend and take a photo after every step to remove any ambiguities.
Also, did you check that there is a magnetic pole in the middle of the coil?
