Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
aether22
I did a test with a compound coil, this was 4 turns of aluminium wire,  4 turns of steel wire, 4 turns of copper wire.
The wires were not connected in any way and 2 of the wires were insulated, so there was no conductive contact between the wires, never the less, this worked!   They are merely inductively linked, except not power is applied.
So this applies to Hendershot, and Hubbard, both of which wound coils on steel cylinders.
Also the Tesla switch  might seem potentially not included, until we recall it has 4 large batteries, likely lead acid, so lead plates, and not just a token amount but really a large amount of lead in series.
So we have:
Rota (big blocks of many metals)
Stubblefield  (main component a bi-metallic coil)
Keely (Tri metal wire basis of work)
Daniel McFarland Cook
Tesla (Tri metal generator)
Moray (2 Big blocks of lead and silver)
Hubbard (Steel Cylinder)
Hendershot (Steel Cylinder)
Coler (Silver and Iron rods)
Tesla Switch (many Lead acid batteries)
Searl (Concentric layered rings of various materials)  Probably also apply to Hamel
Swiss ML/Paul Bauman (Aluminium and iron wire)
Bedini
Perrigo
Steven Marks (Iron wire in coil)
Lakovsky's MWO (not Free Energy, but aetheric energy and health, used rings of different metals)
Dotto (antigravity and health, used ring of copper and copper-Nickle Alloy)
There are no doubt more, this could plausibly apply to the Russians, Kapanadze as well, buried metal, cylinders used as cores...
Is is not amazing that something that very few people include in their unsuccessful experiments (significant amounts of different metals/conductors) just seems to be involved in a huge number of the more impressive claims?
And in the case of Rota and Moray, the inclusion of metals seems very clearly pointed and could serve really no other purpose, both used them in bulk!
So simple, so easy to include in experiments, so likely to be significant and yet basically never tried because few here are students of the connections between the historical Free Energy and other fringe claims.
I can think of other examples, a person who reportedly made paperclips vanish with a high frequency circuit and a steel loop, so that is steel plus copper,  Oh, and welding a Pyramid, that's steel plus Copper.  What about Howard Menger, his coil might have interacted with the carbon rod (might have conducted through it as well), but it should also have likely interacted with the Aluminium disk, and same goes for Hinthorne (Aluminium disk and coils vanished).     So, there you have it, no, by itself mixing metals (especially insufficiently) won't give you Free Energy or Antigravity.  But if you do this along with other guide principles, then your odds of getting Free Energy increase hugely!
A LOT of Free Energy devices BTW don't have a connection to the grid even to start them off, and a lot don't have a connection to the earth, even for ones that tap earth energy a part of the circuit regularly floats!   So having at least part of a circuit floating is another well worn correlation.
I remember a Free Energy device, let's see if it fits this description!
An excerpt from info ion C. Earl Ammann:
He placed some steel bars on a work table and picked up a coil which looked like a loose coupler. After placing the coils on the steel rods he touched the opposite terminal. The bell rang with great force, and there was quite a spark, too.
I picked up the coils to make sure there was no contact with other appliances. I could see right through them. There was no battery inside. The bell rang just as vigorously. The wire was iron.
In the basement Earl had what he called an Activator Transformer, the size of two fists, which had to be within 10 miles of the radius of the generator coils. The activator was not in contact with any visible wires or appliances. It was activated by the electric currents which surge around the earth and activate the compass needle. By cutting into these currents, earl said, we can obtain unlimited power.
A year later Earl demonstrated his Cosmo Electric Generator in Denver. He had placed two copper spheres on the front fenders of his car in place of the headlights. From these copper spheres he obtained enough power to drive that old jalopy all over Denver as reported in the Denver Post at the time.
So, we see Iron wire was used, but he also used Copper Spheres, but, a bell was made to ring, now his coils were iron, but the bell which not more or a reciprocating electric motor would have been standard, and wound no doubt with Copper wire!!!
So there we have it again, copper and iron wire most highly probably combined in series!
aether22
I did a test to see if coils wound around wires/rods picked up their energy, this would apply to Hubbard (already has the cylinders going for it), Bedini (used chopped up welding rods as cores), Perrigo (used nails), Daniel McFarland Cook (iron rods) and probably many more.
I don't believe this would apply to closed magnetic circuits, or magnetic circuits that basically don't support effective aether flows, which would include probably most-all regular transformers.
I also think this likely works much better with round wire/rod rather than flat bar, but that is just a guess.
Sure enough, a bundle of different wire types proved better than a bundle of copper wire wound with a copper wire!
So rods/wires as cores and cylinders both check out, I am yet to check though that cylinders that are cut so as not to present a short circuit work, but I assume it must.
But this general discovery also applies to a startling array of weird experiments, both Free Energy and beyond, this actually applies to at least 8 independent cases of claimed invisibility (and possibly another 3 of which steel and copper were used but I am not sure if the energies combined), all combines steel and copper conduction, I had previously noted the use of steel, but I had not noted that all of these circuit actually were dual steel and copper! (or in one case maybe lead and steel).
If you are interested in the cases of invisibility I can cover them, but most use steel and copper combines, and that's not counting the likes of the mythical Philadelphia experiment which it would also apply to.   Actually another involved a guy vanishing (witnessed) near antennas, Antennas are not made of Copper often and employ Aluminium and steel structure, but are connected to Copper wire, therefore this could be a 9th or maybe 12 example!
Of course other things have to be just right for these results to occur, but can you see how easily this detail is overlooked but it heavily involved in so many cases of Free Energy and weirdness, and when not present there are substitutes to the effect such as multi frequencies and energies (John Hutchison) and different lengths/Pancake coils (Tesla, Keely), amazingly these principles show up where this multi metal thing appears to be lacking!
aether22
I have twice tried to make a post that contains info on correlations on how Conical Coils, Cones, Converging lines/wires, Circular flat discs, wires of different length have been used many times and that some of these devices have produced modest anomalies even with no input power because they are Antennas that intercept a wide range of energies from nature, and both times the post was wiped out because of an annoying mistake!  This is one of the ways to high bandwidth energy.
So, I am just going to include the images and if anyone wants to ask me more, go ahead, also I will add one thing on that subject...
Not only have Pancake coils been used by Tesla, Les Brown, Coler, Markovitch and others (weird story about a pancake Caduceus coil and invisibility from one researcher (Van Tassel)...
But pancake coils have been found carved on rocks around the world, I think for this same reason.
In addition, I thought of another example of Bi-Metallic conduction...
Stan Deyo mentiones the "Wedding Cake" Antigravity experiment, thing is that used iron coils, and yet is connected up to regular copper circuitry to power it, so here we AGAIN have steel and copper, also present in HHO cells, a lot of which produce a product that seems to defy the laws of physics.
THIS IS NOT A COINCIDENCE!
Update: I thought "what about the "Lockridge" device?"  Well, it uses I presume copper wire, but it has 2 sets of Carbon brushes, and as such fulfills the criteria, so might the magnetic field leaking, indeed most any all electric DC type motors for these reasons are likely prone to go OU, likely why they have appeared to do so, so many times.
If you aren't impressed with the evidence for this bi-tri-quad-metal conductor correlation, then you are pretty cynical, or you haven't read or understood the evidence I have presented!    I have not even come close to exhausting the evidence for it and combined with the other methods to achieve the same it might well cover every successful device that has ever done something odd!
In addition, further tests have shown that a split cylinder (so it does not act as a huge Eddy current liability) still works to transfer the energy (split rings/tubes resonate with energy, might even help or be maybe critical).
aether22
I should add, Split rings used as cores for coils has been heavily discussed before and found to be interesting and relivant!
I think also connected to some Russian Kapanadze like designs.
But it will only work propperly if the metal is not Copper, it must be something different!
I also tried split rings of plastic and glass, this worked also.
aether22
The silence if deafening!
I would note that this is not due to radioactivity as earlier proposed, sure radioactivity can be induced, but that's not what is happening here.
Anyway I tested and found that indeed the mass of the metals is absolutely relivant!
I also found a preferred embodiment as attached, where this fits into a circuit is up to the designer, but one example is Moray's circuit
Additionally; Curious, there are still 21 messages (including ads) per page, but somehow posts from the previous page have pushed into this page?!   Have the most numbers changed?  Seemingly they must have, more ads maybe? (ads also have a post number).
