Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
Bob Smith
https://overunity.com/17822/aetheric-transformerinductor/dlattach/attach/169097/
Aether22,
Are you saying that there is a measurable potential difference in copper wire with the dissimilar metals in this configuration?
[size=78%]Bob[/size]
aether22
Quote from: Bob Smith on August 16, 2018, 10:50:00 AM
Aether22,
Bob, it's NOT about potential difference.
Let me explain, there is ample evidence through all the claims of Free Energy and other fringe physics experiments that shows that these effects develop together, in devices plagued by impossibilities, containing an energy besides conventional electromagnetism.  And because it is not conventional electromagnetism, using principles for conventional electromagnetism is assured to lead to failure!
I have found how to feel and affect the aether, but the challenge has been getting it to have physical effects,  My current insight is that devices that I believe to be aetheric that have physical effects have properties that I refer to as "High Bandwidth".
My theory is that when aetheric energy (which happily flows through wires and is liberated by many wires and batteries) has a wide enough range of energy types, it begins to affect physical energies.
Louis Rota Buried large parallel laminations of different metals in the ground (but insulated for any conductive connection) and from these metals came an energy that was not just electrical (in his own words) but which dis amazing things such as make an arc lamp glow.
Now, Stubblefield made a coil with parallel bifilar turns of iron and copper wire, and from this coil he got an energy that was not just electrical that made a carbon arc lamp glow.
Now, Moray used a ground and an Antenna and used large parallel bars of Lead and Silver in his experiment according to one witness, thing is using large bars of metals in this fashion serves no conventional purpose, so this is compelling reason to think this was the cause.
There are other things that should lead to high bandwidth energy, one is a multitude of loads, Tesla always shows lights and motors running from the loads of his generators/receivers, maybe that was needed?
One is Pancake or conical coils, or cone.
But it also makes sense that if we can receive radio through the air or ground, that ground and aerial antennas are high bandwidth!
Spark gaps and arc lamps can make a lot of RFI as well as a wide flat bandwidth of light from UVC down to low infra-red and heat.
So, if we include these other ways of achieving high bandwidth, we see that all of these more famous cases actually used ore than just multi metals, they used Pancake coils, arc's, grounds and more!
Indeed, thinking about it, I am pretty sure that to a large degree the level of achievement is closely related to how well and how many of these bandwidth expanding things they included!  (with the exception of conduction through iron, that seems to be worth a lot!)
So yes, if you join metals and apply heating or cooling on either side of the joins you will get a voltage, and logically if such voltages occur at every temperature as long as they temperature is different, then when the same it means that the voltage exists but is opposing, so there is going to be some small positive and negative voltage, and that might have some useful effect, but it is NOT the point, but it doesn't hurt either!
Number of Asterisks is the number of high bandwidth elements used.
Louis Rota ***  (ground, arcs, multi metal)
Stubblefield ***  ditto
Tesla ****  ditto plus pancake/conical coils
Keely  *** multi length wire fan, multi metal, multitude of different tuned components
Moray **
Hubbard * (maybe **)
Hendershot **  (multi freq tanks)
Coler **
Tesla Switch ** (noisy switching, also one version was run at a radio station)
Searl *** (Multi diameters, multi materials and multiple number sets)
Hamel ** (Aluminium, steel and likely ferrite energy mixing, also cones/vorticies are multi freq)
Ed Grey, **
Perrigo ** (multi metal, and overly complex array with different angles that would likely be high aetheric bandwidth)
Lakhovsky MWO *** (this is the only one that has no Free Energy, however it still suggests there are energetic reasons for these principles.
Kapanadze *** Buried steel ground counts as 2, noisy arc counts as 1.
John Hutchison * A multitude of different electrical gear with different tunings.
This analysis becomes less fruitful with other more recent more marginal cases of Free Energy, is this BECAUSE they don't use these methods???
So, high bandwidth (which is a term to mean complex, many different energies, multi spectral) is about creating a flow of aether that involves a wide range of different energies in order to manifest a more compelling and complete manipulation of the material world.
aether22
"If At First the Idea Is Not Absurd, Then There Is No Hope for It" - Albert Einstein
If anyone doubts this idea, I would like to challenge them to find something that is done in successful Free Energy devices of which we have the most confidence in, and not done much or at all in less successful attempts?
If this is just a coincidence (despite the case that with Rota and Moray it is too plainly embodied to have any other explanation) then surely you can find other coincidences just as compelling?
The amazing thing is that to a very large extent, the experiments that include a lot of these and embody it better have stronger results than those that embody it more weakly!   The exception being some cases of current through iron which I can think of many cases where that has proven to do amazing things!
Also, even if you do not buy the explanation for these design principles, does not mean that you have to reject the correlations themself.
I have looked for correlations for a long time (24 years), I have found none as compelling as this!
Bob Smith
Quote from: aether22 on August 16, 2018, 07:05:58 PM
Louis Rota Buried large parallel laminations of different metals (but insulated for any conductive connection) and from these metals came an energy that was not just electrical (in his own words) but which dis amazing things such as make an arc lamp glow.
Stubblefield ...coil with parallel bifilar turns of iron and copper wire, and from this coil he got an energy that was not just electrical that made a carbon arc lamp glow.
Moray ...ground and an Antenna and used large parallel bars of Lead and Silver in his experiment according to one witness...
...other things that should lead to high bandwidth energy, one is a multitude of loads, Tesla always shows lights and motors running from the loads of his generators/receivers, maybe that was needed?
...Pancake or conical coils, or cone.
...ground and aerial antennas are high bandwidth!
Moray **
Coler **
Ed Grey, **
Aether22,
Great explanation. Hope you don't mind my highlights and selective citing.
I am encouraged by your take on this, and will pursue it further.
You mention multiple loads (in association with diverse elements to conduct aetheric flow). What is it that a load accomplishes in this kind of scenario (rhetorical question)??  The load essentially establishes a kind of gradient which stresses the aether and facilitates or encourages aetheric transmutation, if you like, into useable charge.
I have found that large resistor - say 5 Watts - also helps in this process. It's as though the resistor becomes a kind of gate of transmutation that changes aetheric flow into useable charge. In this sense, the open circuit (i.e.. open to the aether) becomes load-driven:  the greater the load (and resultant aetheric gradient) the greater the flow of aether into the circuit and its transmutation into useable charge to do work.
I don't know if you'd concur with me to this point, but I have a question for you:
Do you believe that frequency plays a role in this entire dynamic?
If dissimilar metals each resonate at their own respective frequencies, is their close proximity actually going to produce a kind of capacitive heterodyning effect, which allows the aether to enter the circuit?
Thanks for sharing your insights.
Bob
aether22
Quote from: Bob Smith on August 17, 2018, 11:44:34 AM
Aether22,
Bob
You highlighted a typo where I typed "ore" but meant "more".
Do you recommend I use highlighting to make the main points stand out?
I'm glad you will Pursue this further, I think it is a smashing correlation.
"You mention multiple loads (in association with diverse elements to conduct aetheric flow). What is it that a load accomplishes in this kind of scenario?"
To answer your question despite it's Rhetorical nature, the loads do 2 things I believe, but, MAYBE 3 things or more.
The main one I am promoting right now is to consider each material, energy, frequency as an increase to the aetheric energy bandwidth of the aetheric energy coursing through the device.
Another one which is relivant and might be connected is what I term "Processing", this is where the aetheric and conventional energy is for instance a wire are both transformed in the same location, and that by doing this the 2 energies become mingled.
I have 3 theories, which might be different perspectives of one thing, or might all be occurring, one is disintegration of the physical energy by the aether, another is that the aetheric energy begins to mimic the conventional energy, and the final is a hybridization, where the 2 energies mix and the physical energy becomes transformed.
But, whatever happens, the physical and aetheric energy should be re-absorbed and re-emitted again and again I believe it become progressively more physical.
I know for a fact this DOES happen.
It is also on my radar that potentially something occurs when conventional energy shows a high degree of entropy (such as with a heater) that the aetheric energy might invert that into Extropy.
However, there is also an effect whereby much as you state, aetheric energy passed through a resistor amplifies the energy of the field it is in, this is a curious effect I have observed, but no conventional energy is needed for this effect to be observed.
I have found for instance that some patterns, or interesting shapes or geometries, while they seem inactive by themselves, placed near an aetheric resistor they increase the energy hugely, one such example is a Mobius strip, or, the likes of the Sri Yantra or the Flower of life.
This seems to do 2 things, energy is radiated and maybe even pulled from the form placed near it, but the energy manifesting, radiating from the resistor is structured by this field, i need to understand this better, also interesting things happen with a square grid or other tessellation.
As for you large resistors, is this with electrical power flowing through? (e.g.  5 watts of of electrical power?)
Or with just an aetheric power?
"Do you believe that frequency plays a role in this entire dynamic?"
I believe that there are some frequencies that are 'Special".
I believe that higher frequencies means more self inductance with less resistance, this means that circuits "proccess" (transform energy between potential and magnetic field and back) at a faster rate and this improves results until a point where the losses from too high frequencies become too great, this depends on the quality of the circuit it is harder to make a circuit that is good at say 500khz than 20khz and really hard at MHZ frequencies.
Also, Frequencies in the sense of multiple frequencies absolutely make a difference, John Hutchison is the prime example of what multiple frequency spectrum energy can do, this stimulates more bandwidth of aetheric energy.
"If dissimilar metals each resonate at their own respective frequencies, is their close proximity actually going to produce a kind of capacitive heterodyning effect, which allows the aether to enter the circuit?"
I had to look up Heterodyning actually, for those like myself, it basically refers to a beat frequency which is the difference from mixing of 2 higher frequencies.
I have no answer really, there is so much unknown, each element might be a basket of frequencies (if that is even the way the energy manifests), and we don't know how close they are even if each element has a distinctive frequency.  And I'm not sure if beat frequencies would make aetheric energies or aether enter the circuit.   But it is easy enough to test electrically to see what a beat frequency would cause.
But another interesting thing I have found to occur with the aether is that if you have 2 frequencies displaced in space, it creates the frequencies between in the space separating the 2.    For instance if you have 1khz and 2khz signals, in the space between aetherically you will get every value in between.   This works with frequencies, colours, numbers, and more.
So, I have not thought to do this with elements, or really to apply this to this high bandwidth thing yet, but I should try it, I have been meaning to.
Ok, so I just tried it, a short length and a long length either side of a of a longer bar, this created a high bandwidth energy (which feels very dense).
So, this might mean picking 2 elements, say Aluminium (14)  and Lead (82) either side of Carbon (6), the idea is to choose something not within that range to sit in between.
Ok, that's easy enough to try, but I'll use Bismuth (83) as I have that on hand...
Yup, that worked very well!
So, you can create a very high bandwidth by using 2 different metals either side of a main conductor!
Maybe the Silver and Lead in Moray's design were not stuck directly together, but sandwiched a copper conductor?
This would capture numbers between 47 to 82, which is to say those values should be created as an aetheric signal between those elements.
I have 2 signal generators, and one can make 2 frequencies, so I can create 3 different frequencies, and by using square waves i have create harmonics, so I should test this as well, including used this spectrum effect.
