Homopolar generator idea
Started by Antiproduct, October 01, 2018, 03:55:41 PM
0 Members and 16 Guests are viewing this topic.
shylo
In the video what would be the result if you spin the stator and magnet?
One in both the same direction, the other in opposite directions?
I would think the voltage would double.
artv
F6FLT
Quote from: shylo on March 01, 2019, 04:54:39 AM
artv
agreed.
The answer was above. Here are all cases:
1. Disc rotating + stator at rest: voltage
2. Disc at rest + "stator" rotating : voltage
3. Disc rotating + "stator" rotating in the same direction : zero voltage (due to no relative speed)
4. Disc rotating + "stator" rotating in the opposite direction : twice the voltage (due to twice the relative speed)
In any case, magnet rotating or not rotating: same effect
If case 3 provided a voltage, you could charge a capacitor connected between the axle and the rim of a Faraday disk and rotating with it. I did this experiment to be sure: no voltage.
I rotated the disc with the capacitor for a while, then I accelerated the motor, which disconnected the capacitor by centrifugal force on the rim contact. But at the arrival after stopping the motor, the capacitor was not charged!
seaad
Quote from: F6FLT on March 01, 2019, 09:26:39 AM
Right motor is constantly spinning. Readings center to rim.
Left motor: magnet rotating + or -,
or not rotating at all: same effect
F6FLT
Quote from: seaad on March 01, 2019, 11:35:00 AM
Never believe without verification!   ;)
Good point, and nice demonstration!
shylo
So the stator has to see the disc in motion,and as long as a magnetic field is present a voltage is produced.
If you put on a second stator,could you collect double the voltage?
Or stators on both sides of the disc,reverse polarity but still a voltage?
artv
