Real overunity transformer with ancient technology
Started by IonLady, May 08, 2019, 04:30:40 AM
NdaClouDzzz
Quote from: NdaClouDzzz on December 24, 2020, 04:14:27 PM
Can anyone translate the attached screenshot of some YT comments into a schematic, and comment on the validity and viability of such a scheme?
I think I get it.
Because the refrigerator compressor/motor is a fixed load (except at start up), you can use caps to run the motor coils as parallel LC circuits, and thus reduce amp draw!
Some informative videos that may help someone in understanding:
fun with lcs  https://youtu.be/uNYUu1VL1aM
Energy Propagation  https://youtu.be/kQdcwDCBoNY
Resonant rise of Parallel LC  https://youtu.be/x-1EKjOtrPM
NdaClouDzzz
I found the answer to my question posted above, no thanks to all of you members who've been here long enough to know about this but couldn't be bothered to post a link!
                                             CAPACITANCE LOWERS INDUCTION MOTOR AMP DRAW BY 80%
https://overunity.com/6606/induction-motors-and-capacitors-lowers-amps-consumption/
https://youtu.be/63tX67HnwGw
https://youtu.be/VdHmQR1FEjg
https://youtu.be/HYSdSwNdl0c
https://youtu.be/lSKWstQMqy0
https://youtu.be/EAoUnws81kw
https://youtu.be/pLQRsexvUuM
Capacitive induction motor and method https://patents.google.com/patent/US6331760B1/en
NdaClouDzzz, beside to listen :
https://peswiki.com/directory:james-jim-f-murray-iii
60 Hz conventional = 3600 RPM need ,by his tecnique 1800 RPM
and
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=meta+c+&IN=dinnan&CPC=&IC=&Submit=Search
especially
https://worldwide.espacenet.com/publicationDetails/description?CC=TW&NR=200627764A&KC=A&FT=D&ND=3&date=20060801&DB=EPODOC&locale=en_EP#
Table 6
Attention related PF : https://en.wikipedia.org/wiki/Power_factor             is a dimensionless number in the closed interval of −1 to 1
Also related : inrush current and inrush voltage  and " inrush limiter" or use as "interval pulse power"
To note the numbers game :
https://drivesncontrols.com/news/fullstory.php/aid/4917/_91Re-invented_92_fan_motor_cuts_energy_use_by_up_to_80_25.html
Until now, the commercial refrigeration industry has had two main choices for fan motors: induction, or shaded-pole, motors, developed in the 1880s, which account for more than 65% of all commercial refrigeration motors in the US and are only 20% efficient; and electronically-commutated motors (ECMs), developed in the 1960s, which currently have a 35% market share and are about 60% efficient.
The new Q-Sync motor has a claimed efficiency of 75% and is similar in cost to an ECM. At the heart of the patent-pending design is a simpler, smarter controller.
20%/75% as "up to 80% energy savings" ratio  case !
Sincere
OCWL
AlienGrey
What transformer ? it's a motor  your pointing to and i don't want some bozo taking over my computer witch could happen if i down load there control software.
AG,dividing internet and intranet !
Chips with integrated software : Eprom
And when Nda... writes about motor process controlling I give only some more open source links,
with the advantage or choice from rotoric principle ,like couple Hector's rotoverter,to mechanical non-motive principle,like Hector's transverter , to change  : in practical !
Power factor and inrush phase to differ between grid source and closed battery/capacitor circuit,when then negative PF is also called : feedback !
Kanarevs 'pulse power' measurement compared 'inrush phase power' measurement !
Battery action/reaction time versus ultra/super-/capacitor reaction/action time !
Wmax per second comparison !
Steinmetz circuit ! N.Tesla lost when Steinmetz left the Tesla-Steinmetz partnership !
Sincere
OCWL
