Tadahiko Mizuno LENR breakthrough COP of 5 and up to 10 Seeking Replication .
Started by ChileanOne, July 03, 2019, 05:39:45 PM
ChileanOne
After looking if this has been posted before and not finding a mention of it in Overunity.com, I present you with the following important news regarding the ongoing struggle for proving LENR (Low Energy Nuclear Reaction, which was once erroneously called Cold Fusion) from Dr. Tadahiko Mizuno who recently published the preprints for his upcoming participation in 22nd International Conference for Condensed Matter Nuclear Science (ICCF 22), co authored with Jed Rothwell, and which was published online with the express intention of the authors of provide as much as detailed information about the experimental set up, methods of preparation, calibration and measurements, as possible, to enable replication and independent confirmation of these results, something unheard of in this field of research, specially for results of this high level of excess heat, which has been for years stuck at the level of 3 (not counting unverifiable claims from commercial companies that publish a lot of results but always keep a part of the recipe secret).
The detailed paper can be read here:
https://www.lenr-canr.org/acrobat/MizunoTincreasede.pdf
However, the authors recommend strongly to read the precursor work published in ICCF 21 because the methods and set up is mostly the same and only the reactor configuration changed slightly for obtaining the later, strikingly important, results.
https://www.lenr-canr.org/acrobat/MizunoTexcessheata.pdf
Highlights:
With an input power of 50W electric for the heating element, the reactor puts out 300 watts of thermal power.
With an imput power of 300W electric for the heating element, the reactor puts out +3000 watts of thermal power (estimated based on surface and room temperature increases, as their air flow calorimeter can only handle up to 1000 watts thermal output).
At that high thermal output, it was rapidly adopted as a room heater for the harsh Sapporo winter in Dr. Mizuno's home.
https://www.lenr-forum.com/attachment/8710-pasted-from-clipboard-png/
As the publication has garnered a lot of interest within the LENR community and many have perused all details and a heated debate of the results has been ongoing, already a supplementary article with more details has been published (along with several updates and clarifications to the paper in the first link posted) all made in the spirit of providing the most accurate possible depiction of how the results were obtained to encourage replication by as many people as possible around the world.
https://www.lenr-canr.org/acrobat/MizunoTsupplement.pdf
For anyone interested it must be said the replication, even if the setup is remarkably simple for an LENR experiment, is not trivial and an accurate replication will probably require to spend a good sum (US$ 3000?) due to the nature of the experiment and measurements required. However, the Nickel mesh burnished with palladium is going to be available from Dr. Mizuno himself, and you can enquire and coordinate for obtaining it here: https://e-catworld.com/2019/06/22/question-for-replicators-anyone-interested-in-testing-mizuno-nickel-meshes/
If you like to join the discussion and interact directly with Jed Rothwell you can sig up to LERN-Forum and go to the Mizuno Excess Heat discussion thread here:
https://www.lenr-forum.com/forum/thread/6013-mizuno-reports-increased-excess-heat/
or join the "Mizuno Replication and Materials Only" thread there, here:
https://www.lenr-forum.com/forum/thread/6017-mizuno-replication-and-materials-only/
Hope you find this information encouraging, I invite your comments and hopefully you get interested in starting a replication on your own.
ChileanOne
Deneum Technology, an exotic energy start up with labs in Estonia, is the first public attempt to replicate Mizuno's R20 reactor. They have already published a video of their setup and will be running their experiment through next week.
https://www.youtube.com/watch?v=TWZ-uXQTF_s
ramset
Thank you soo much for starting this Topic !!Was aware of the claim recently ,and now some fun !..we have open source members that are very excited about LENR and can experiment,
will be sure to pass this along . thx Chet
your link again
PS  This link where materials can be accessed was not opening for me? [in NE USA]
snip// mesh burnished with palladium is going to be available from Dr. Mizuno himself, and you can enquire and coordinate for obtaining it here:  here the link should be copied but it shows blankIf you like to join the discussion and interact directly with Jed Rothwell you can sig up to LERN-Forum and go to the Mizuno Excess Heat discussion thread
Thanks Grandma
https://www.resoheat.com/
C. O. P.: 5 claimed
without Palladium or LENR
( probably some do remember : the claim and the fallacy : https://en.m.wikipedia.org/wiki/Patterson_power_cell )
C. O. P.. ?
https://patentauction.com/patent.php?nb=11451
By the same:
https://patentauction.com/patent.php?nb=11462
The resoheat motor equipped with the Russian "magneto"- power amplifier. ?
resoheat 150 sqm house example : from 25000 KWh to 5000 KWh using Mizuno/resoheat !
                    5000 KWh Electric Energy to german e-grid Primary Energy(Factor 1,8) : 9000 KWh PE
                   9000 KWh PE /150 sqm = 60 KWh PE /sqm
                   compared
                   2020 : E.U. Nearly Zero Energy( new) Building consumption standart : 30 KWh PE
                                       Passive solar house energy consumption standart 15 KWh PE / sqm
                    60 KWh PE /sqm divided by "power amplifier" factor 5( Tanaka Saburo)
        or factor 10 ( " magneto/ Dr.Imris)
                    means 12 KWh PE( T.Saburo) down to 6 KWh PE ( "magneto/Dr.Imris) primary energy
                   per squaremeter
                     and annum : electro-technical "Active Solar Energy Standart"
ChileanOne
Quote from: ramset on August 04, 2019, 07:34:12 AM
your link again
The link for the survey of people that were serious about getting prepared meshes by Dr. Mizuno is already dead, it was a short term query. You can still try to reach Bob Greenyer through the contact form at www.quantumheat.org and see if there's room for more people, he was coordinating the effort. The price of the 3 sheets was set at US$ 400 plus shipping, as it was intended to help somewhat Dr. Mizuno's delicate financial situation.
