Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
WhatIsIt
At one point he is feeding frequencies into colector coils.
At another he is feeding frequencies into control coils?
Jeg
Quote from: tomd on September 24, 2019, 06:40:03 AM
1) Is he talking about wave superposition or more appropriately pulse superposition?
2) Is this why the voltages are slightly out of phase considering the energy produced if the waves are in phase?
tomd
1) That was my first thought. Three pulses the same time same direction. It would be a nice strating point.
2) By using beat frequency, phase changes all the time. At one moment and depending on the beat, both frequencies eventually align themeselves and both kicks are the one over the other. But there is also the third coil. I can't visualise how it would perform an action of this kind and what araingement needs for this.
Turbo
Quote from: WhatIsIt on September 24, 2019, 06:52:46 AM
Okay Whatisit you are making a lot of noise i have posted some explanations many years ago and i have updated them for you so that you can read it and understand a little bit more about how this all came to be.
I will re-post it for you to see if it can be of any assistance to you to help you to understand the process.
Here it is :
The first frequency generates the kicks.
What are the kicks ?
The kicks are a burst or release of high energetic particles in random directions.
These kicks are generated by a process that i have so far called 'stimulated nuclear transmutation'
Some difficult words, maybe, but don't walk away yet i can explain it in simple terms.
Alternating magnetic fields running at certain specific frequencies can alter nuclear conversion between the elements thereby releasing energy.
In the early transformer experiments, Steven hit on a NMR frequency of the iron transformer core, which in turn started to release massive amounts of kicks.
These kicks were released perpendicularly away from the core and were all flying away at high speed and in random directions.
This is what Steven observed in his very first experiments and he rightfully called them kicks.
This was not very efficient as such, but Steven indeed discovered and identified this as the bare-bone effect.
Notice this has got nothing to do with the earths magnetic field, but how on earth could he know what was going on?
So the earths magnetic field was his first thought as it would be mine, It's a pity most people still hold on to the old dream.
Okay back to the explanation:
Steven then discovered that when he run the transformers slightly out of phase, he could maximize the effect.
After he discovered the kicks, he was immediately facing a new problem because in those early experiments these small energy bursts were launching electrons away from the emitting iron cores in perpendicular lines, in random directions and he found it was hard and in-efficient to extract any real energy in coils by means of classical induction....,until he began to run the transformers slightly out of phase.
He noticed it made a difference when there was one transformer coil powered whilst the other generated the effect.
Thus he somehow figured out that a strong magnetic field was needed to force all of the chaotic radiated electrons in a straight line through a coil as soon as they were generated/released from the core.
This is somewhat similar to what a yoke does to control the electron beam in a CRT television tube.
And he knew how to do this, his education at the tv repair shop served him very,very well.
So, now this process is explained as follows:
The first frequency generates the kicks.(in random directions... chaos)
The second frequency energizes one of the (control) coils, right after the kicks are generated.
Because the kicks are high energetic (electron) particles, they will deflect when they enter/interact with the strong field created by the (control) coil that is energized by the secondary frequency.
This strong field will force all high speed electrons into ONE DIRECTION. <-- AND THIS is important ! (squeezing the hose)
This is called 'Combining hundreds of thousands of little kicks into one big current kick . . .'
So at this point we have 'rectified' or 'redirected' all of the kicks into one direction and this is the point where we fire the third frequency.
The third frequency creates another strong magnetic field (or pulse) and this deflects (or dumps..) the high energetic electron beam back into the collector coil, thereby generating the 'big current kick' Steven writes about in his memoirs.
So as such, the control coils are used to deflect the high energy particles and force them into one direction, and they are also used as a means to an end, to collect the energy into the collector coil(s).
I hope this helps you to understand the role the control coils play in the process.
Lets say these 3 events are called one cycle:
Generate - Deflect - Collect
It is possible (and likely) that Steven used permanent magnets to deflect these high energetic electron particles, in his early/first devices.
In that respect you could drop the 'tunnel' or secondary frequency, or if your setup/design is really clever, perhaps also the third... but that boils down to design.
Soon Steven developed mechanisms of using feedback involving multiple receiving coils in a way that he started the reaction from a power supply and then he extracted the energy from the first coil and used this energy to establish the strong needed electron deflecting magnetic field for the second coil and so on to the third and you guessed it, from the third to the first and now things started to look quite interesting...
He kept improving the designs and this eventually led to the famous videos everyone wants to know more about.
So here you have it, i hope it helps.
WhatIsIt
Hi Turbo,
Yes it helps.
Thank you for explanation!
I will read your old posts and try to catch up.
rensseak
Quote from: Turbo on September 23, 2019, 09:55:59 PM
No they are not coils from SM.
Those are very wrong in design.
They aren't on top of each other neither vertically nor horizontally because they are interleaved.
Too bad people keep injecting garbage into the tread.
You can use the searchable pdf file to find how its arranged.
Use search terms as collector and control and coils.
Turbo, if you know it so good, where this picture is coming from and what do you know about them?You mean what is mentioned in the pdf file comes all from SM? Who was drawing the arrangement of the coils?
