"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
synchro1
Quote from: skywatcher on December 06, 2019, 03:40:14 PM
You mean this sort of ring magnet ?
https://media2.supermagnete.de/themes/pdesign/pics/icons/rings_outline.png
That's an axial polarized ring magnet. A tube would be longer. The static field appears in the hollow core, but it's irrelevant. Dr. Stiffler sandwiches first a high perm bifilar toroid coil then a HV capacitor between a stack of Neo discs to modulate the static field. I use a 1" diametricly polarized tube magnet in my synchro coil and wrap it with copper windings. The capacitors on the two receiver LC tanks would need pico farad tuners to get the twin resonant "Q". Crystal oscillators are trouble free.
Two quantuum coupled "Synchro Coils" in static field resonance should share the same rise in voltage potential transmitted through the capacitors from one to the other. A second receiver would rise in voltage from the scaler value along with the first receiver and the transmitter.
I'm talking about touching a 9 volt battery, to the transmitter capacitor electrodes, which could be any one of the three receivers. We charge one, and the other two or multiple numbers would rise to the same voltage instantly tuned to the same static field resonant frequency.
Toolofcortex
Well I guess Synchro1 that you do a crappy job @ explaining then.
Your audience is not getting you.
synchro1
Quote from: Toolofcortex on December 06, 2019, 04:36:36 PM
Position two Neo tube magnets next to crystal oscillators with tin foil attached and batteries connected, so both magnet core static fields resonate at 13.56 Mhz. These magnets are now coupled in the quanta and a superluminal pathway opens between them.
skywatcher
So let's say i have a cylindrical neo magnet (you said the hole in the center is not important) for example i have some N42 neos with 10 mm diameter and 60 mm long.
Then i need a crystal oscillator tuned to 13.56 MHz. Is any other (tunable, but stable) oscillator also possible ?
What i don't get: How is the oscillator coupled to the magnet ?  Is there a coil ?  A picture would be helpful.
synchro1
You will get it eventually. Stienmetz: There are two equal energies in the Universe: One static (Energy) the other magnetic (Matter). E=MC2. This is the Lorentz force field dielectric ratio of magnetism and voltage.
The infinite voltage inside the static magnet core field is equal in potential to the static field in the vacuum of space that surrounds it. This constitutes a fifth dimension, continuum or Quanta (Whole). This field is not in space and time. Modulation of this field is in counterspace.
Voltage has no magnetic value. Electricity does. This static field oscillates from static (electricity) not an electrical connection. The static Plenum of zero point (Infinite Voltage) is outside the material and physical World.
Everything else is insulator dielectric, blocking this power around itself with magnetic field lines. This field shows up inside the Neodymium magnet core dielectric as C2 (Light Squared) power field potential. That is equal to everything around it with nothing in the way. So a signal through this (Hyper-Dimensional rabbit hole) goes everywhere with no resistance or impedance. Nothing to slow it down. Instantaneous and superluminal.
