Real Free Energy from magnets !
Started by r2fpl, March 09, 2020, 09:21:54 AM
conradelektro
Quote from: lltfdaniel1 on March 09, 2020, 03:02:38 PM
What i am saying is, there is real torque and power with the earths rotational fly wheel, and when you connect your magnet with it, the potential goes into your magnet, meaning your magnet can self sustain with rotational moving as well as powering a generator with a load and fully work that way.
Like a fly wheel of a car engine, and a inter link flywheel see it that way.
Your tapping into the earths flywheel of motion so as the earth moves there is momentum and when your magnet communicates with it, in a compass like way where it won't stop spinning is how that is done.
I am afraid you are getting carried away. But if you have fun, it is ok. The invention of free energy, what a feast.
I just want to remind you, the earth will stop turning (eventually) if you tap into the earth's flywheel (if you really could).
Greetings, Conrad
r2fpl
Quote from: conradelektro on March 09, 2020, 03:07:39 PM
Exactly what I am claiming, the weight of the magnet bar (or ring magnet) together with the string (its properties) cause the spinning (till the string reaches the limit of its stretchability).
Use a fishing line (technically speaking: a monofilar string)!
I don't have it now monofilar string:(
the weight of the magnet doesn't mean it spins faster or slower. It is rather related to the shape of the magnetic field.
ok I don't know why the magnet is rotating. Maybe it's the fault of the string and tension when stretching.
More tests need to be done.
Do none of you have two magnets to perform a similar test ?!
skywatcher
Quote from: r2fpl on March 09, 2020, 09:21:54 AM
I did some tests with different magnets and they all rotate CCW. If the white thread were not twisted, the magnet would spin all the time. These are the features of Free Energy!
Do you have something which is similar to the magnets in weight and shape, but not magnetic ?
Like some big washers, or an object made of glass would be even better because it's also non-metallic.
If such a non-magnetic object doesn't spin with the same rope, but a magnet does, then we have something interesting.
lltfdaniel1
Quote from: conradelektro on March 09, 2020, 03:14:05 PM
Greetings, Conrad
Well if it will stop turning, that means no real potiential energy to power a load and with the way the earth operates it should have stopped turning some many years ago, and this has to be tested because like earth and like the machine that taps the flywhee of the earthl behaves the same and you know this.
But while is still turns you can still get the momentum of it and power a load, and if this device with it's resistt loads can stop it (the earth) even further then whey but the earth has no friction it is 100% though regarding friction free.
But what sustains the earth motion i reckon is like the casmir force effect, the acceleration of the motion maintains the equal speed of the earths rotation, just a theory.
It is indeed a form of tapping the earth's flywheel from the obvious interaction.
Yes am getting carried away anyways it is like a form of solar power even the sun will die.
Dan.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
