Real Free Energy from magnets !
Started by r2fpl, March 09, 2020, 09:21:54 AM
citfta
If the experiment in the first post was actually showing free energy from the earth's magnetic field then compasses would be useless because they would always be spinning.  You could hang a lead weight on the string and see the same effect.  The weight is causing the string to untwist from its naturally twisted condition.
lltfdaniel1
Quote from: citfta on March 10, 2020, 06:35:10 AM
Gyroscopes and how they work is what i am on about, the gyroscope will keep momentum moving forever.
Like the compass effect, but view the compass effect with the gyroscope.
Study the gyroscope very closely and you will see the true nature of the physics regarding it.
Can a gyroscope produce electricity?
This precession of the spinning gyroscope is then used to drive the rotary motor generator to continuously rotate and thus generate electricity. The entirety or a portion of the generated electricity may be directly used to power an electric load or device.20 May 2008
https://www.physicsforums.com/threads/will-this-gyroscope-spin-forever.823092/
Gyroscopic effect is ability (tendency) of the rotating body to maintain a steady direction of its axis of rotation. The gyroscopes are rotating with respect to the axis of symmetry at high speed
It seems my idea of tapping earth fly wheel has been fully been accomplished and did not know but the gyroscope is the perfect example of my tapping earths flywheel, it also tilts like the earth so yea.
In the absence of forces to dissipate the energy and momentum of the gyroscope, it will continue to precess forever.
https://www.youtube.com/watch?v=ldqUV-DXiUg
https://science.howstuffworks.com/gyroscope1.htm
https://www.youtube.com/watch?v=6q0qXRetpB4- some gyroscope free energy overunity device
Gyroscope is not fake technology you can buy them all across the internet like amazon below as well as many many many websites.
https://www.amazon.co.uk/3B-Scientific-U52006-u52006-Gyroscope/dp/B07D3JZPMG/ref=asc_df_B07D3JZPMG/?tag=googshopuk-21&linkCode=df0&hvadid=394232177913&hvpos=&hvnetw=g&hvrand=10891209039558515925&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006548&hvtargid=pla-867117200574&psc=1&th=1&psc=1&tag=&ref=&adgrpid=80755809974&hvpone=&hvptwo=&hvadid=394232177913&hvpos=&hvnetw=g&hvrand=10891209039558515925&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006548&hvtargid=pla-867117200574
Or here below
https://en.wikipedia.org/wiki/Precession
https://patents.google.com/patent/US7375436B1/en
Also more importantly watch this > https://www.youtube.com/watch?v=4mD6fHYQ694
This picture link below shows the compass like effect where it find's no axis and in the process keep spinning forever, precess forever with the momentum.
https://scontent-lhr8-1.xx.fbcdn.net/v/t1.0-9/88331300_10158073423452375_2511814221797261312_o.jpg?_nc_cat=110&_nc_sid=8024bb&_nc_oc=AQmMg6xAITA8q99XdpRu0V7GFmbfCHukdsJZXXao9oMRH86SiExg0cLLSv0987u8B5U&_nc_ht=scontent-lhr8-1.xx&oh=82f8a93bb179e36de286cafe7a79fd4f&oe=5E8EE7DA
The concept proof of how the gyroscope works is the anti virus for the physics world and there has been heated debates about it because of that, with how it works.
With the same exact principles of the gyroscope you will have a working gravity motor.
The way the gyroscope works is internally not externally tapping into the earths magnetic or gravity or both, flywheel ;-).
This gyroscope is what people needs for free energy so read this > http://blog.fabric.ch/index.php?/archives/394-Harnessing-the-Energy-from-the-Earths-Rotation.html
There are various different techniques with the gyroscope effect.
https://www.youtube.com/watch?v=DsOU0WEc6OU
it is a solid proof concept > https://energyeducation.ca/encyclopedia/Gyroscopic_motion
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lftdaniel1 , what will be a static "flywheel" ,no macro-mechanical movement  ?
from macro-mechanical rotations  : 1 Rotor-wheel  x 1 RPM to 10,100,1000,..... RPMs
                                                    2 Rotor-wheels x 1,10,100,1000,...... RPMs
to electric micro-turns :
1 turn/winding-coil/foils        x 1,10,100,1000,.... Ampere-turns ~ 1,10,100,1000 ,.. rotation/-s
10 turns/windings-coil/foils  x 1,10,100,1000,.... Ampere-turns ~ 10,100,1000, ...   rotations
https://www.youtube.com/channel/UCF0Xz9h7mOde4y39ANX9DBw minute 8:50 how this "static flywheel" is to construct !
3d magnet printing : how and when happens the "out of printer" device alignment ?
lltfdaniel1
Quote from: lancaIV on March 10, 2020, 09:10:48 AM
We are pretty much on the same wave length, by seeing for what it really is instead of reasoning with what we have been taught or what mainstream science knows.
I know and so do you that the electro static nature is imbalanced like like the exact principle of the gyroscope same applys here but if you try to tap the flywheel externally you are cut off from it due to laws of energy which is external thinking.
If the gyroscope can do it internally then for sure this electro static method is fully possible.
Because of gyroscope you are using electrostatic,
Anyways the gyroscope taps the flywheel of the earth and the energy it gives during the duration of when it spins the output will be far far greater then the input to maintain the spinning process.
If you ram up the rpm using gears to make the rpm faster of this constant speed of the flywheel process well i do not recommend it because the load would be too much for it to sustain it self, but if left at its constant speed then this won't happen and will work as in self sustaining during its spin period along with excess power to be used for a load.
