Simple and powerful principle
Started by nix85, March 17, 2020, 07:30:59 PM
Floor
The tram presented by LankIV is also, I think very cool.  Elegance in simplicity.
By its not O.U.. LankaIV knows this very well / is not claiming it to be O.U..
Ask him your self.
   best wishes
   floor
seychelles
CHET MY THEORY IS THAT THE FLYWHEEL GAINS ENERGY FORM THE FORCE OF
GRAVITY. THE FLYWHEEL ACCELERATION NEEDS TO BE FASTER THAN THE GRAVITY
ACCELERATION, WHICH IS 9,81 M/S SQUARE. PLUS THE FLYWHEEL HAS TO BE POWERED FROM
IT OUTER RIM, TO GET THE EFFECT OF LEVERAGE.
seychelles
THE GENERATOR IS CONNECTED DIRECTLY TO THE FLYWHEEL SHAFT.
seychelles
THE FLYWHEEL IS GOING THROUGH THIS ZERO GRAVITY WHEN IT PAST THAT 9.81M/S SQUARE.
https://www.youtube.com/watch/HQbAwE83phk
Quote from: Floor on January 29, 2021, 11:42:01 AM
Ask him your self.
   best wishes
   floor
https://www.overunity.com/watermotor/index.htm
compared Mandelstam/Papalexi parametric generator !
Both underunity per cycle,overunity in additive cycles sum !
point of view science and measurement : https://techxplore.com/news/2020-08-black-silicon-uv-responses-efficiency.html
Sincere
OCWL
p.s.:
https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=4304132A1&KC=A1&FT=D&ND=3&date=19940818&DB=EPODOC&locale=en_EP#
In Fig. 6 a paddle wheel is shown, I built this paddle wheel, it is driven by four pumps with a combined power of 900 watts in a circulation process. These four pumps put eight liters per second, in this case water, into the paddle blades. This means on the fall side of the paddle wheel for eight blades of the wheel a weight of over 70 kg and that at the outermost edge of the wheel. The paddle wheel has a diameter of 1.80 m, which results in a radius of 0.90 m, an enormous leverage effect. It goes without saying that a 10 kW generator can stall with such force. If I hadn't stood by it myself, it would be incredible for me with today's technology. FIGS. 2 and 3 are portable power generators and intended for installation in vehicles for locomotion.
        1994-08-18
                 written 10 000 W generator output / 900 W pump motors input ratio : sufficient error reserve !
                                        down to                       450 W pump permanent magnet motors input ,2021 standart
f.e.: claimed double efficiency https://www.linkedin.com/company/thor-power-corporation
from the paper water wheel to :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3621312&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
https://patents.google.com/patent/DE3621312A1/sv
compact water wheel turbine:
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19801211&CC=DE&NR=2922736A1&KC=A1#
citing documents !
