Nelson Rocha Workbench
Started by hartiberlin, April 30, 2020, 02:57:05 PM
NickZ
   Guys:   I believe that Nelson has a plan and a purpose for his thread. Without it being filled up and cluttered up with more off topic subjects.  There are other threads, for that. We are here for Nelson's ideas and tests.  At least I am.
   Nelson:  Thanks for your explanation concerning the self runner, that is not self running.
However, I'm still confused. Does that mean that the device runs for a little while (as shown on the video) once the power is cut off, and then stops once it used up it's reserved power? A simple Yes, or  No, would do for now.
Raycathode
Nelson High hope you are well.
Any chance you can explain to the guys here what a nano pulse is and why it is used
there does appear a good bit of confusion and contradictory beliefs and miss understanding.
Some say it's a falling transition and others say it's a rising transition
Others say it's the width of rising and falling pulse or is it inverted?
Thanks so much Raymondo  ;)
nelsonrochaa
Hi Chris ,
I appreciate your thoughts and I would one statement about what I think.
"Of course, this series of Magnetic Interactions in the proximity of the Conducting Coils, is important, of course Electromagnetic Induction occurs every time The Magnetic Field Changes in Time, or the Current Changes in Time in proximity to the Conductors."
Electric current produces a magnetic field . But  Magnetic fields can also be used to make electric currents ,exist  a connection and mutuality between both .
we call current to the rate of flow of electric charges in a conductor or by example in a coil of wire .the higher the speed this charges can flow, the higher is the current, like the opposite happens when a magnetic field is accelerated, the current will increase too. This makes either the current in space or the magnetic field in time have reciprocity between them .
Our mind normalizes all motion to unit time this way a reduction in time is equivalent to an increase in space.
It is also true, that the variation of an electromotive force, in space and time also generates a displacement current.
So a time-varying electric field also produces a magnetic field and vice versa. Thus, we can see that there is a symmetry between electric and magnetic field.
This is the point that i am most interested in exploring:) :
Displacement currents. That's my main reason for this project with bifilar pancakes coils.
When a pancake coil is exposed to a high electric field, depending on the dielectric materials that make it up, there is a polarization of those  materials, oriented their positive charges in the opposite direction to the negative ones, giving rise to a electric field and this yields an internal electric field inside coil ,Perhaps that is the reason for Tesla underline a voltage gain in these bifilar pancake coils.
The energy gap in the dielectric material's is very large and being the air a dialectic agent, we could theorize the possibility of exist a interaction between positive and negative ionic charges existing in the environment as a way to draw energy from outside to the coils.
Are those charges static?
Tesla mentioned in some of his quotes, about these charges not being static ...
Was he referring to the Displacement currents?
Who will know?
A good theme to explore :)
Best Rewards
Nelson Rocha
nelsonrochaa
Quote from: Raycathode on May 28, 2020, 01:17:47 PM
Hi Raymondo ,
I think the vast majority most know what a nano pulse circuit consists of.
It is usually characterized by Short duration, fast rise time electromagnetic pulses . However, care must be taken when using these types of circuits, as they may cause irreversible damage to your health.
This type of circuit can even create cell mutations.
Take care
Best Rewards
Nelson Rocha
nelsonrochaa
Quote from: NickZ on May 28, 2020, 09:54:51 AM
Hi Nick ,
I will answer you doubts without low details , but the enough for you to understand.
The circuit self-feedback that you talk , have a pre-charged capacitors;
when i use the 9volts battery is only to start the electronic circuit system and to start the circuit control  after that the process of feedback has able to maintain the oscillations , and the circuit control system will start discharge in a "special way " those capacitors , but at same time, happens a process of "recycling" on the load on the output and that portion recyclable  is injected again in the input , ensure the operation of the control circuit, and recharge the capacitors in a loop.
The system can operate for a few minutes or even hours, depending on how it is used and the type of load used (inductive is the best) I designed to use in a motor .
This circuit was designed to have an external input, based on brake regeneration, or even a solar panel on the vehicle's roof to prolong the effect described.
The idea would be to increase the autonomy of an electric vehicle through this process that I described to you. In that time I work on that project the model granted by Daimler, was a Vito E-CELL .
It was a really interesting project but it is not an OU system.
I hope you have clarified it.
Because you are still involved in your project, by Kapanadze Cousin I'll share a bonus :) Make good use of it :)
https://photos.app.goo.gl/J6uVSprTRCjRBaie6
Best rewards
Nelson Rocha
