Nuclear Magnetic Resonance (NMR)
Started by Smudge, May 26, 2020, 11:16:02 AM
kajunbee
Quote from: Smudge on July 05, 2020, 04:43:38 AM
Hi Kajunbee,
These are not solenoidal coils, they are flat pancake coils.  We don't use the axial field that passes through the coils, we use the radial field that passes over the flat surface of the coils.  In the bucking configuration the axial fields from each coil do indeed oppose each other, but the radial fields between the two coils are additive.
Smudge
So would I be correct in saying that you effectively create a Quadrapole magnetic field also referred to as anti-Helmholtz magnetic trap. Looking forward to your response and thank you for your time.
Smudge
Quote from: kajunbee on July 06, 2020, 10:57:58 PM
Yes, two magnetic dipoles back to back create a linear magnetic quadrupole.  But normally the terms dipole or quadrupole are reserved for poles that are points sources, and that is not the case for current loops.  For the pancake coils it is quite difficult to define where the poles are, they are spread out through space.  If you put a cylindrical box around both coils then the two flat surfaces of that cylinder can be considered say N poles while the curved surface is a S pole (or vice versa).  That may look like a tripole and many people fall into the trap of calling it a tripole, but in fact when two dipoles are brought together so that the mating poles merge into each other you end up with just three poles, but the correct name is a linear quadrupole. (A square quadrupole has the two dipoles side by side and then there are four separate poles)
Smudge
Smudge
......................also referred to as anti-Helmholtz magnetic trap.
Such traps do not use pancake coils but yes, the two coils in opposition act somewhat like those traps.  Classical Helmholtz coils create a cylindrical spatial region where samples may be put so as to be in a uniform axial field.  This anti-Helmholtz arrangement using pancake coils creates an annular spatial region where our circular water sample may be put so as to be withing a radial field.
Smudge
stivep
Quote from: Smudge on May 26, 2020, 11:16:02 AM
This Board is set up to encourage experimentation of NMR as a potential source of over unity-energy.  Nuclei having a magnetic moment precess around a magnetic field at the Larmor frequency.
If all the nuclei in a sample can be made to precess in synchronism then they can act like a perpetual generator supplying power.
That this may be possible is evidence by Ramsay (one of the early researchers into NMR) where he describes the experiment
as a spin system at negative temperature where he states "
It was found for example that, when a negative temperature spin system was subjected to resonance radiation,
more radiant energy was given off by the spin system than was absorbed".   The attached paper gives details of the experiment.
Smudge
When someone speaks Chinese the only  left for us Westerners  form  of communication is paper  drawing and  sign language for hearing- impaired   individuals.
Language  of physics uses characters of e.g English language  adds to it its own symbols, forms equations, meanings  and rules needed to communicate in this language.
So  lets take  Chinese trying to explain something in Chinese,+ sign+ drawings, but he doesn't know  physics and is totally wrong.What would you learn  from him?
Chinese  students are occupying our American  universities  to be able to communicate in our universal English language.
But  if they are not educated in language of physics than their English explanation  may be  incorrect.
So some of them who knows  English  and are in Physics  can  correct other Chinese..
Conclusion:
every language  doesn't need to explain  meaning of blocks of information  widely known with words such as: Earth, air, flow, mechanics, baby, art, and so on..
But there are  professionals in e.g mechanics and some others in science of e.g mechanics.
Their knowledge is higher  than average Joe in that particular field.
________________________________
So you Smudge need to  try to talk in language of physics using English   descriptors .
But what if you  only know English  but  only to some extend  physics?
Well than you need help from these who speaks physics better..
But how do you know that someone is not wrong in physics and knows it better than you?
Well By  using process of verification  in the internet  you can differentiate between  e.g dull Russian troll  and  professional.
Yes : Talented Russian troll may fool you too because he is paid money for  confusing you and sending into wrong  path.
Yes:  there are people like me who are not paid  and dedicate their time  for others to understand physics better.
Yes:  I can be mistaken too , but that will be surprise to myself too.
__________________________________________________________
over unity-energy.   doesn't exist never existed and will never exist.
perpetual motion is fiction. It doesn't exist never existed and will never exist.
Eather  doesn't exist never existed and will never exist. but it was just  a concept- a model rejected by science .
so these meanings or information blocks  must be excluded as  totally wrong till anyone will come with supporting  it explanation.
But using these blocks to explain anything is wrong.
Example :
1. Using magic or God teaching to explain
difference between effect of sperm of  human  causing  birth, and other mammals sperm causing the same.
2. physics doesn't recognize any "gods or any magic" so these blocks must be excluded  as false models of the past
for physics we are just HUMAN ANIMALS  whether you like  it or not ....
____________________________________________________________
conclusion:
we may find  and I'm sure that there  is  way to  use NMR
in the processes associated with energy conversion and energy extraction .And this alone is worth of my time  here.
Wesley
stivep
I do thank you for this topic as it is  important to our FE community
Wesley
