Magnetic Air Coil Generator MAG
Started by BorisKrabow, July 26, 2020, 01:55:16 PM
BorisKrabow
If you take it seriously, then I must say
      the field of a permanent magnet located in a ferromagnetic requires a lot of energy to be controlled by an electric coil .
  this is the main reason for the failure to find free energy. For this reason, the best researchers admitted defeat. this has been repeated for decades.
                              To solve the problem, you need to take extraordinary measures .
BorisKrabow
Quote from: BorisKrabow on July 29, 2020, 04:17:27 PM
Hi  Seychelles ,
                             This is my design of your design    ;D   ;D
Best regards,
Boris
                 You and I created a fantastic design .  The air gap is adjusted to make the system unstable  .  Now the slightest fluctuation of the magnetic field in the modulator  will set in motion an avalanche of magnetic field !
                                                  And voila a whole sea of ​​Overunity    ;D   ;D  .
Jeg
Quote from: BorisKrabow on July 29, 2020, 10:53:29 PM
Great key point!!! Seems that you have mastered this idea. Well done and thanks a lot once again!
Or the air gap is the water channel in magnetic air coil electrolyzer or MHD or MED !
Adjustable permanent magnets with electromagnet combination !
Variable mmf and emf device
Whom interests John C Ecklin his work will probably also interests William J Putt his ouevre !
BorisKrabow
"  .....  Whom interests John C Ecklin his work will probably also interests William J Putt his ouevre !  "
   Hi !   LancaIV ,
                          I just looked at patents  William J Putt .     He has good ideas .
             Maybe I'll make one design   ;D
Best regards,
Boris
