Place holder for Patrick Kelly Tribute / open source experiment
Started by ramset, July 28, 2020, 09:50:52 AM
sm0ky2
Quote from: NRamaswami on August 03, 2020, 12:31:29 PM
..high voltage magnetic fields were used in permanent magnet cores..
As we know from electronic acoustic engineering,
this will place a physical force on the coil opposing the magnet.
If you managed to hold the coil stationary, the same amount of energy
would still be lost applying force to an immovable object.
NRamaswami
Sir
Very respectfully I have no theoretical knowledge. I don't even understand what you have written.
My knowledge is limited to conducting some experiments as desired by Patrick. All he suggested were failures. The only device Multiple Wave Oscillator was successful when built as indicated.
In view of the inaccurate information received by him and believed to be true by him, Patrick asked me to play around and try to learn the following.
Building an Electromagnet
Building a permanent magnet
Building a powerful Electromagnet
Building a Powerful Electromagnet using the minimum amount of wattage.
Attempting to build a COP>1 device
I was left to my own imaginations to do these things and no instructions were given.
I have done all these things within four months starting from the scratch in 2013.
Experimental validation and experimental results were deemed to be the truth and I ignored what is stated in the books for I did not understand much of it or most of it.
I have read Mr. Forest saying that induced EMF comes only from the strength of the magnetic field and this is correct.
I apologize that I'm not able to understand or answer what you have written. No longer interested in this subject as this only drains my energy and money.
Regards,
Ramaswami
NRamaswami
Sir
Are you saying some thing about a single system..
What is single system
One transformer
containing one primary and one secondary where the coils of wire are of equal weight regardless of the gauge or number of turns.
In this kind of devices output cannot exceed input.
Output in this type of cases will always be less than input
It is simple. Straightforward.
This is the kind of things discussed in books.
I ignored the books and played around by experimenting with different types of windings devices shapes et al.
Nothing spectacular about that. If you give a toy to a kid and tell him to play with it,  the child is very joyful and plays around with it.. If you tell him that he can make and brake and create a lot of shapes the creativity of the kid makes it do a lot of things. This is what I did. Subject is very addictive but very expensive to experiment and very time consuming.
Unfortunately I did not study Maths and so do not understand calculations. Many times I thought the results received by putting in values to online calculators were wrong but I could not understand these things. very sorry about that.
My understanding is that what I write you may not understand and what you write I do not understand..
Regards,
Ramaswami Natarajan
onepower
NRamaswami
QuoteBuilding an Electromagnet
Magnets are peculiar things. It takes energy to produce a permanent magnet and yet many say it has no energy within it. This would seem to violate the conservation of energy because as they also say, energy cannot be created nor destroyed only transformed. So if we produced a permanent magnet by adding energy the energy must remain with the magnet and it's field which also implies the energy can be removed because energy is conserved. A magnetic energy storage device if you will.
Strange isn't it?, that some would claim to believe energy is always conserved in every form then in the next breath imply it wasn't in a permanent magnet. So, which is it?... is energy conserved or is it not?.
NRamaswami
Sir
I don't understand your point really.
My observation is that a substantial force is available in the permanent magnet. It appears to have a life of its own if I may say so.
A permanent magnet is able to recognise the presence of an electomagnet even when it's five to six feet away from an electromagnet and starts vibrating.
Opposite poles jump towards each other even when they are kept 9 to 10 inches with great force and the magnet is damaged.
Identical poles repel eachnother turn so the opposite poles can look at each other and then jump towards each other so they can form a large permanent magnet.
I tend to believe that some kind of energy is present in nature. When a permanent magnet is made the magnet starts acting like a focusing lens kind of device. The energy appears to move in one direction from one pole to another.
When opposite poles are shown the magnet jumps to form a bigger magnet so the energy can easily flow. Identical poles try to prevent the flow abd so they repel each other turnaround and then merge to form a larger magnet.
Therefore I believe that a significant silent energy flow from the energy of nature is present in the permanent magnet.
Patrick Kelly would repeatedly point out that only one second DC current is needed to make a permanent magnet. After that unless heated it will always remain a permanent magnet.
This is why I think that there's a concentrated energy flow within the permanent magnet.
Please note that this is my belief. I have no proof.
Ramaswami Natarajan
