Place holder for Patrick Kelly Tribute / open source experiment
Started by ramset, July 28, 2020, 09:50:52 AM
NRamaswami
I think I have to clarify this
I have tried to experiment with saturated cores..how long they will take to heat up etc..
I think it is this that has created the problem
We can easily avoid it by a shielding or just by standing away at a distance
Magnetic fields very quickly dissipate with increasing distance
I also had prior health problems that got aggravated..other healthy staff who are younger and who worked with me are not affected..
So it's not very scary..most researchers are not young...so if you are quite young and healthy and fit just standing away at a distance with a grounded metal plate should block these fields..
Frequency is only 50 Hz but it's the intensity of the magnetic fields that are worrying
The pick up coil..if it means secondary coil then your understanding is not correct about multifilar coils
A multifilar coil actually increases the inductive impedance in AC. It requires alot of voltage for the same current to flow through it and prevents or reduces the flow of current at lower voltage.. This inductive impedance is not present if we used pulsed DC..when we put a diode bridge  to AC the output from that is pulsed DC.. this is my understanding and probably my terminology is wrong..I apologise for any mistakes.. secondary or output coil if made bifilar or multifilar shows lot of voltage but once we give any load shows zero voltage..no use..
No..very low voltage experiments don't produce any results..I started with 12 and then went to 40 and then moved to 220..I didn't dare to go beyond that..In Tesla coil we have gone to 7500 volts AC but it's so fully shielded and 100 milliamps small transformer and the resulting radio frequency Tesla coil we limited to 120000 volts.. radio frequency and so not much to worry..we were able to draw sparks upto 4 inches but as it's radio frequency and testing is fir seconds only nothing to worry. These were done with Electrical Engineer trained in high voltage..
Hendershot was reported to have used 1600 volts and Hubbard 11500 volts but this kind of information very quickly disappeared..
McFarland Cook patent is believed to be incomplete..he talks about giving an initial input and then says the electrimagnets remain self oscillating.. this is possible only if very large and very high voltage and very high capacity capacitor bank is used. There were at least four sets of coils and the presence of capacitor bank is required to create an illusion of motor generator kind of thing..the system would be oscillated only so long as the capacitor bank is not discharged. My impression was that at that time saturating the core would have been a technical problem to be solved and saturation of core was required to make a powerful permanent magnet..
This type of large and very high capacity capacitor technology is reported to be lost..it would have been taken out of literature..
There's no instance of Cook device being used anywhere..
I have not trusted anything written anywhere by anyone but experimented and verified..most of the time I and Patrick found only misinformation being presented as the correct information..
No one would give away technology and most of the time it is delay,divert, deviate, disrupt and make it obsolete to be used in technology..
The only free energy device is the Tesla's Radiant Energy Device patent application.
Even here Patrick was very insistent that the top plate is a capacitor bank of high capacity to which spark from a Tesla coil was employed.. Patrick was insistent that Don Smith demonstrated that using this method anywhere from 100-1000 amps would flow from the capacitor to the ground.. Tesla coil needs high voltage and not current..but there's no indication about the capacitor plate at the top in Tesla's Patent application. There's obviously no information available about the capacitor.
Therefore please don't believe anything that you read.. experimental results triumph every thing written..
Patent or non Patent disinformation is common..
Patrick believed one description of a device to be very genuine coming from a very honest person..
When I built the device each step of the way we had to send him photos for him to verify that the turns are wound properly and the number of turns matched the description..
When we built and tested it it didn't work..in fact electromagnets in half the place failed to magnetize while the rest were magnetized. Information provided to him was not accurate. I have spent a lot of money and time on this and Patrick was disappointed to say the least. Offered to reimburse me which I declined.
This is for very trustworthy information given in confidence. You can very well imagine what is the credibility of info written in other places..
Experiment verify and then only you can trust it.
A self runner would need high voltage,high voltage capacitors, bleeding resistors for safety, spark plug to drain excess current if any, a tertiary that cannot be seen by Primary..these are minimum requirements..
I am told that I am not entitled to do research at high voltage..I was told to limit myself to 12 volt DC or 40 volt AC. This is what Patrick also stipulated..As there was nothing to learn I went upto 220 volts.
Therefore no self runner.
A tabletop self runner means that the builder is an expert.. Tariel kapanadze and our good friend Nelson Rocha are the only people who demonstrated it many years ago..lots of testing and competence required for this..I tried to use low voltage very large and very low current saturated magnets but it didn't work..
Any every time we measured more output than input by the combination of secondary and tertiary coil Patrick would say no notes disassemble and forget..so no memory with me either..but it's possible to build more output in combination than input devices.. even at lower voltage levels..
Anyway only thing that I do today is why did I do all these crazy things.. lots of knowledge but no use..any experimenter must realise that this is a money draining learning curve and avoid it unless they can write it off.
Not all experiments are successful. Unless you have financial support don't do this
A free energy device is the simple solar panels based device available commercially. No risk of high voltage or large Electromagnetic fields. However unpalatable this is the reality. I could have easily purchased a 10-12 kilowatts solar panels based device for this expenses but knowledge would not be available. But at least your family would not find fault with you for the expenses incurred. So you have to take all these in to account before you invest your energy time and money.
Ramaswami Natarajan
Jeg
Quote from: NRamaswami on August 02, 2020, 01:14:58 AM
Mr Ramaswami
May i ask what do you mean by "tertiary coil" that is not being seeing by the primary? Is that some kind of a choke or transformer in series with the secondary? Did you use it as a mean to extract the reactive power?
Thanks in advance
Jeg
NRamaswami
Sir
I apologise..I might have forgotten about these things..long time ago I was studying these things..
Please try to find out if I have misled you by winding the simple induction coil where the secondary is wound on both sides of the multifilar primary
Please ascertain if the secondary merges..
Please see if my memory is correct that it may be possible to exceed the input if we reach the twice the voltage of input at the output..
These are things that I tested many years back..due to poor health I have not been active in this field..
My experience was that we need to jump in to the water even to attempt to learn to swim..
Please find out for yourself if I am speaking truthfully or misleading you..
To attempt to answer your question Thane Heins  transformer stated in the book of Patrick comes to mind.. please check it. Not everything may be true and you will have to find out yourself.. many typos and my apologies
I am very grateful for your trust but I am not sure of my own memory..so much of time has passed..
Ramaswami Natarajan
Jeg
Sir NR
I really don't want to bother you more on this as you already have enough concerns in your own personal life. I already understood the basic points of your experiments and it would be really amazing if something innovative will occur out of this approach. Yes, the only way out is personal involvement and testing. I wish you the best and take care! :)
Jeg
sm0ky2
As far as i can tell, the Clemente devices were all pulsed DC from a 12v battery
or equivalent voltaic stack
the distributor-style contact points were abrupt and caused a great deal of friction and sparks
these devices are not dissimilar to the device that eventually made its way into the automotive industry. The 16-stage distributor from a diesel truck would be a very close replacement to the original "part 3", timing would be adjusted by a resistor to the small motor one would use to replace the rotary action caused by the engines crankshaft, or by using a magnetic potential between the needle and positions around the switch, as one done in the late 19th century.
Digital conversion will result in slightly different waveforms, but im fairly certain the effect we are experimenting with is not inherently frequency dependent, as Tesla pointed out with 60Hz application, but rather a function of induction, capacitance, and reluctance.
it is correct to say that the inductee' (pick-up coil, secondary, output whatever you call it) determines the timing.
The time it takes to saturate the secondary coil is the amount of time the first primary is electrified.
The time it takes to desaturate the secondary coil is the amount of time the second primary is electrified in opposite polarity.
[please note here that the clemente drawings, as well as my own show both primary coils as separate, however they can be a reversed multifilar coil in the same manner as i show for the secondary]
Mathematically, maxwell predicts a time between saturation and desaturation, where the current changes direction, but its value is so minute as to not be of our concern in the circuit timing of our devices.
The situation this device creates could be called an "assisted desaturation" of the secondary coil.
This increases the output current in the same step we are increasing the voltage by adding the secondary in series.
A meter at the 'center tap' of each secondary should show not only a voltage increase, but an increase in power, at each junction.
