Place holder for Patrick Kelly Tribute / open source experiment
Started by ramset, July 28, 2020, 09:50:52 AM
Jeg
Quote from: sm0ky2 on August 01, 2020, 10:17:45 AM
The casing from a desktop computer would provide more than adequate protection, at a much greater cost.
Thanks for the info smoky!
Does the case need grounding of some short?
sm0ky2
Quote from: Jeg on August 01, 2020, 10:26:49 AM
If you did it would only be to the common of the battery circuit.
So long as you arent powering it from the utility mains,
there should be no need for a true 'earth ground'
Jeg
Cool! I think i'll modify my bench for safer experiments. Thanks a lot! ;)
sm0ky2
Quote from: sm0ky2 on August 01, 2020, 10:28:32 AM
If you look at how the electronics ate grounded when there is a power supply or voltage converter or sorts, the case is only grounded to the converted source, not the ground plug of the 3-prong
The POWER supply, however, is grounded on the back end, which is why if you have something like a 120 to 12v converter you may see 3 in the wall and only a + and - on the 12v side.
The 12v circuit (if grounded) is then grounded to the (-) of the 12v.
sm0ky2
Also:
If you earth ground a battery circuit anywhere close to civilization,
You are introducing a potential voltage.
