Towards A Complete Maxwell's Daemon System
Started by d3x0r, July 30, 2020, 07:07:01 PM
onepower
D3xor
You said...
Quote, "things not immersed in electromagnetism-, the spaces between galaxies that are not along the axial vector".
No problem, it just stuck out because I couldn't understand the line of reason used.  Something cannot translate between two points without occupying every space in between. This must apply or violate the COE thus electromagnetism and EM waves must be universal everywhere. Otherwise were into the something from nothing/ vice versa fiasco.
d3x0r
Quote from: lancaIV on August 24, 2020, 03:16:23 PM
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20200514&CC=DE&NR=102018008797A1&KC=A1
translated :
http://translationportal.epo.org/emtp/translate/?ACTION=abstract-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=102018008797&SRCLANG=DE&OPS=ops.epo.org/3.2&TRGLANG=en
', thermal energy in a ratio of 1 to 10 can be obtained with a saving effect of 90%! '
That's great; but we need less thermal at this point :) Heat doesn't disappear, it just dissipates; does emit a little, but I'm sure emission IR is a very small portion of the heat photons that get sent off into space
Well I dunno, is it reversible like a Peltier(?)
d3x0r
Quote from: onepower on August 24, 2020, 03:29:12 PM
D3xor
You said...
Oh I see; I did say 'electromagnetism' it's so much immersed as transporting though...
Just because a pipe is moving fluid it's not necessarily 'immersed' in fluid.
Quote from: d3x0r on August 24, 2020, 04:44:19 PM
I do not think that the description model shows  a reverse method !
But from the same inventor a device for heating or cooling,tipo resonator, electricity in = heat out or heat in and electricity out,here propagated C.O.P. 8x  !
onepower
Concerning our Energy  Demon...
Maxwell proposed the law of thermodynamics may be violated due to a control measure, his Demon, actively separating high and low energy particle/states. In fact it's true and most people have Maxwell's Demon in there house, lol. The trick is to actually understand the concept and process described then find analogies. Here Maxwell is describing a process in which heat (molecular motion) is not transformed into another form of energy but simply separated or moved. We should know this concept well because every heat pump, air conditioner and refrigerator is based on it.
We are not generating heat energy due to an energy transformation nor are we transforming heat (molecular motion) into another form of motion. The heat pump uses a process to capture the heat energy then move it to another place using the least extra energy possible. In fact this is what Maxwell is describing and it only violates the laws of thermodynamics so long as one cannot understand thermodynamics or how energy can be moved without an energy transformation... but not in reality.
You see it's not what the law is but how it's applied, how one interprets it and it's easy to build something which appears to violate most laws. I do it all the time and most people don't have a clue how I can do what I do and it may as well be magic to them. For example, I built a passive magnetic bearing and then posted the details here in the forum. Everyone said it was impossible, cannot be done, they could not understand it then I showed them a picture and everyone did a facepalm. You see Earnshaw's theorem states it's impossible to have a 100% passive field based control mechanism because it's inherently unstable and it's true for obvious reasons. However my magnetic bearing didn't violate Earnshaw's theorem because it was only 99.99% passive not 100%. Therefor I win, without actually violating any laws.
On the other hand, Faraday's Demon wasn't referring to something as primitive as thermodynamics or a heat pump. Faraday was referring to the inherent motion he supposed was within all material things relating to electrodynamics. We now know this as atomic energy relating to the motion of the particles which make up the atom. As well, just when we think it couldn't possibly get any more strange it turns out Faraday got many idea's from reading the Vedic/Sanskrit texts just like Tesla and many other great scientists at the time. It's strange, people talk of all these great scientists and inventors however they don't have a clue who these people really were. They were basically quacks, just like us so were in good company, lol.
