The two capacitor paradox debate
Started by onepower, September 02, 2020, 01:19:20 PM
WhatIsIt
Quote from: v8karlo on September 05, 2020, 03:33:23 PM
In one of his videos Don Smith said
Source of FE is high voltage because voltage is squared.
And he was refering to this energy equation.
But, can cap make 4 times of real work with doubling voltage?
And 4 times of energy is needed to charge cap,
So, energy in out is the same.
No free lunch.
What is needed is method to charge cap cheaply,
cheating energy equation, and use difference.
But you know that already.
The similar "para = against dox= teach" :
Mukherjee generator F1= BIL ,when F2= 1/2BIL we need for compensation 1/2 the voltage and 1/2 the amperage
Fradella generator :1000 rpm gives 1000 rated Watt output
                                      500 rpm gives 0,5x0,5x0,5 = 125 Watt output
                                     100 rpm gives 0,1x0,1x0,1 =       1 Watt output
                              10% rated rotations gives only 1 promille= 0,1% rated energy gain !
onepower
Kajunbee
QuoteAs you see the discharge time is twice as fast but peak power of resistor is 4 times as high.
As expected, which proves what exactly?.
We should offer justification for what we mean and say otherwise it is basically meaningless. So what was your point, where were you going with it, by what reasoning?.
Here is a good example by Iancaiv...
QuoteThe similar "para = against dox= teach" :
500 rpm gives 0,5x0,5x0,5 = 125 Watt output 100 rpm gives 0,1x0,1x0,1 =       1 Watt output
It is basically nonsensical gibberish and while it may be factual it has no context anyone can seem to understand. It's like a person writing in Chinese and expecting everyone else to understand it when they cannot read Chinese. Use your words gentlemen, express your idea's and concepts in ways others can understand...that is the way we communicate.
" Nonsensical gibberish",probably , for anybody who does not know the right formula application !
Para-dox or non-linear ~ dynamic
kolbacict
Hi all.
Now, if a chemical reaction takes place between the charged plates of the capacitor, the equilibrium
will be biased towards the formation of a product with a higher dielectric constant?
Just like our temperature shifts the equilibrium towards exo and endo reactions.
Because with a decrease in the permittivity of the dielectric, the energy of the capacitor
grows (tantamount to the spreading of the plates) and this, as it were, does not fit
. E = U2C / 2. That is, it will appear as if from nowhere.
Am I right ?
