free energy via electronic means
Started by ring_theory, January 03, 2007, 10:12:39 AM
Walter Hofmann
Hi pese ,
thats exactly what I sayd long time ago this stair waye is exactly what brings this work to what it gives. My unit worked for more then 1 year at my workshop till I finally had my grid power up.
like I also sayd back then that I took out the circuit from the charger just used the transformer and the rectifier and it worked perfect.
Like you sayd the whole sytem will not work with most electronic devices even the charger circuit can not work properly.
just my two cents.
greetings
walt
Quote from: pese on January 26, 2007, 06:19:36 AM
it is correct but if it say sine - this inverts are "modificated sine"  (so the instruction papers)
that say that the dodificates sine , will make from starecase
wit on (somtimes alse more) step to hight and to down.
thet are steps , tat make pulse  , if motors transormers an so on will be driven with that !)
Not anyy devicewill work proberly with this , also some elecronic devices will not work !!
Are shure , that i know this inverters , i have over years repaired , also design (alsothe oldone with Power germanium transistors and Transformer , that can make "proper  SINE".
I  have to say ONLY :  It "can" be made an difference to use
This or ANOTHER Inverter to drive your charger.
I CAN?T say , that the one or the other will worf in the "offered"
scematics.
Gustav Pese
ring_theory
pese
it do nothing (no difference) for
the charger and his retifier diodes , IF them will powered with 50 or 60 hz
Pese
Quote from: lancaIV on January 16, 2007, 12:52:15 PM
the easier ,Anton jun. Wallner, system :
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DE29812556U&F=O
go to "Originaldocument" then "drawings":look Figur1(mono-phase)
and think about the description-thesis:
the generator power of 220V/5A is amplified by this
welding-transformer-(feedback)interconnection to a motor-side
220V/30A power output !
S
  dL
p.s.: this transformation is not possible with DC equipment !
       Conversion would be a need !
       On 29.01.07 I phoned to A.j.Wallner and he told me that his concept is
       operable,but has to be grounded !
       The power output of his prototype has been in the 220V/16A range
        and only with mono-phase equipment !
       Without grounding there has been a neutralizing feedback of the hoped effect !
gyulasun
Quote from: lancaIV on January 31, 2007, 04:36:12 PM
Hi Lanca,
Has the inventor told you which side of the mono-phase set-up has to be grounded?  The generator side on the left or the motor side on the right?
Or: the transformer primary coil or the secondary coil is to be grounded perhaps?  Have you asked these?
Thanks for sharing this info, sounds interesting (and misterious).
Gyula
