free energy via electronic means
Started by ring_theory, January 03, 2007, 10:12:39 AM
ring_theory
Walter Hofmann
Hi ring theorie,
I just wana tell you , dont be surprised if you use new parts instead of the old ones that it may not performe like with the old ones or not at all. I am talking from expirience.
greetings
walt
Quote from: ring_theory on January 22, 2007, 08:24:22 PM
Quote from: hartiberlin on January 22, 2007, 03:07:45 AM
@ring_theory,
maybe you can post a picture of your real setup ?
Many thanks.
Regards, Stefan.
I've been putting off building a demonstration rig for my van till i can get some new components. I want to have a professional looking rig for demonstrations. with nice looking connectors etc. I also don't have much in the test equipment way meaning a watt meter, o-scope, or any other test equipment to give readings that will be demanded here. all I have is one volt/ohm meter.
A friend of mine says build it anyways, and just "tell them that if it works this good using used and antiquated components imagine how well it would work with new and state of the art components." He's got a point. However I'm trying to sell these things and old and antiquated components doesn't show my workmanship. especially when the battery charger face is falling off. I ran it over, goofy me.
I may do it anyways i have a few motorhome/RV lots i would like to visit to generate some sales of this.
IronHead
Newer microchip controlled and sensor protected chargers / inverters do no not work ,from what I have found.
My old inverter seems to be way over built and the charger I'm using is an older  Timer 10 amp charger with the time bypassed.
Straight 10 amp , No power factor drops and so on.
You might try what I am doing with the old stuff .That is, build a nice case with meters and such built in. Or even buy a sufficient
size premade project box.
However you go about it good luck all.
pese
@ W.H.
Yes that is it.
The modern inverter have not sinus output ( square wave or "modified sinus" , that is
only an "word" to sell this devices better!). i say it before, it is a different to have an sine 50 or 60 hz Inverter , with bir iron/copper transformer to an new modern "lowercost  "High frequency switching  inverter with added 50/60 Hz "former" . If this "device" was working
jears ago , and possibly in only "one singel" construction , that it "can" be taht the
SINE -Output , compare "harmonic" to the "sine" input frome the charger , and will produce "eventually" Overunity .
In this way also "some" mechanical devices are working properly ...
(if the frequencies run "harmonic" and not with lost again each other - same
is valid vor TPU?s)
This will be an "hard work"  or "fortune" to find THIS out.
Pese
ring_theory
