free energy via electronic means
Started by ring_theory, January 03, 2007, 10:12:39 AM
Hallo gyula,
desculpa me,
mas neste momento nos somos a constituir uma empresa,
por essa razao eu nao tenho muito tempo !
Anton jun. Wallner spoke about grounding of the motor-side !
Ate breve
             de Lan?a
p.s.:  http://v3.espacenet.com/origdoc?DB=EPODOC&IDX=DE3900890&F=08QPN=DE3900890
Eu falo com o Sr. von Heyer,
ele explicava me que o sistema so trabalha quando a entrada nao ultrapassa
de 7Hz para 1Hz ,mas melhor 1/4 Hz !
Above: Overheating risk !
gyulasun
Hi Lanca,
Thanks for the infos. I wish you good luck for your  *empresa nova*.
I think the reason for von Heyer's machine to work better at the lower Hz region (<1Hz) is that at such a low frequency eddy current loss cannot manifest so much.
rgds,  Gyula
Hello gyula,
denomina?ao (registo comercial) : Enerciencia Energia Lda.
Sede,escritorios (estabelecidos) : Lisboa,V.N.Gaia
Ate proxima
                de Lan?a
IronHead
I am still waiting on parts to be delivered .
Dingus Mungus
Quote from: IronHead on February 08, 2007, 10:33:23 AM
Have you already started on your scooters baseline measurements? I'm most excited to see your results, you should show some lifetime gain based on others claims of running workshops and campers on this system for weeks. If you have good logs on the scooters lifetime and power averages without the system, you'll be able to determine the gains or losses with a simple ratio once the system is installed. I wish you all the best on your experiments! Don't forget though more weight will drain more power, so you may want to try to remove as much dead weight from your components as possible.
~Dingus
