free energy via electronic means
Started by ring_theory, January 03, 2007, 10:12:39 AM
IronHead
The scooter has been reconfigured from stock 36vdc at 750 watt  to 48vdc at 1000 watt . Battery configuration is 4x 12ah 12vdc series. Now achieving 25 mph form stock at 15mph.
I am getting from a full charge ,10 to 12 miles flat out constant full throttle with 180 Lbs payload. Winds at 0 to 4 mph. All test were preformed in a cross wind.
This test was run 6 times .These results will be posted at a later date with any new results in a more organized fashion.
ring_theory
IronHead
It's going well but slow.
I am building everything from the ground up , charger and inverter.
I found out Quasi  single pulse per phase is the way to go.
Just about finished with the inverter build ,but at a standstill waiting on more parts.
The variable pulse charger is also nearly  complete.
The platform (Scooter) has been modded out abit to create a better test bed than a stock scooter.
If this works out as well as the bench test . I will be doing an all electric full size
motorcycle next. This will include a pulse motor that I designed.
IronHead
Startup and study of a three battery system. 600 watt transformer type Quasi inverter .
Charger is transformer and rectifier type no caps. Charger adjustable pulse system not installed yet.
Just getting started with 2x performance. More to come!
Just Build It!
IronHead
mkt3920
Quote from: IronHead on February 23, 2007, 09:22:54 AM
Just Build It!
IronHead
Ironhead,
Any additional info?
Kent
