Free Energy RANT CAFFE ASYLUM
Started by v8karlo, October 02, 2020, 03:11:51 PM
SolarLab
Quote from: SolarLab on May 03, 2023, 05:57:23 PM
Nick,
Here's a good example one for ya:
You and your freezing friends should try this - been done by many, pretty much "off-the-shelf"
and is probably one of the more easy ones to quickly build and make use of
(also check for links around this post for more info) but don't forget to check the oil once in a while:
https://overunity.com/19422/topruslan/msg576293/#msg576293
P.S. - You can run it in the house - no fumes - but get a low "dB" Inverter Gen type (low noise)!
Have fun...
SL
Clarification and Comment
Why post an old "WATER FUEL Test Set" and a link to an HHO Generator?
Since no one asked or even commented - here's why:
The Forbidden WATER ENGINE is REAL | We created an engine that runs on hydrogen
by The Liberty Engine Project ( https://www.youtube.com/watch?v=eacLgrqRdyk )
Devices similar to this (pure electrolysis) were tested more than 10 years ago using this "Test Set"
and it showed there was OU but the Generator will only run for <5 minutes on a fully charged
battery even if the battery is being charged by the generator alternator.
Even at near full power output from the A/C generator the operation is unlikely to "keep up" with
the electrolysis production. There were many calculation iterations done and not many really came
close to a "self looping" capability.
A great deal of work was done a few years ago regarding this approach. Not mindless chatter - but real work.
Too bad no one remembers! So, the point is "why bother doing or publishing anything?"
It appears it's all for not... Anyway, back to watching TV!
Then again, you do, most times, get what you pay for - right! Free energy for free = 5 minutes  ;)
But who knows, if you hang long enough waiting for free stuff, maybe you'll get lucky!
SL
ramset
Solarlab
In this forum and others
Are tens of thousands of hours ( gross underestimate)
Of hho powering experiments ( attempts at running genset or cars ..
I believe DogOne shared his experience ( and related back injury from trying to
Run his truck on a heavy HHO genset unit ?)
Nowadays these vids only bring video revenue to creepy guys ( even my above reference
To sonny miller's magnetic twistdrive work ( prototype demonstration vid )was pirated and used as revenue stream ( yeah ugly stuff indeed)
That being said
The open source LENR community has been chasing true anomalous heat or Energy gains
In water and "other" ....forever ...
Never give up trying
Nor do they hide their work ...
Hiding is "same old same old"
And usually attached to Attempts to monetize..
Open source ...the only path forward ——->>>
A patent or patent application..?
Handing a man a stick to beat you with ( FE patent application)
BTW
Pretty cold comment on Nick's "freezing friends (in Ukraine) "
Yeesh
Thanks Grandma
SolarLab
Quote from: ramset on May 04, 2023, 01:13:18 PM
Solarlab
BTW
Yeesh
Ramset,
Thank you for sharing all that - I feel much better now! Have a nice day...  :-[
SL
BTW, is this your idea of a pun? => "BTW  Pretty cold comment on Nick's "freezing friends (in Ukraine) " Yeesh
Not going to go any further with this one...  :-X
Anyway - sorry - but I missed your point; if there even was one?
Willy
Intentional or not, you diverted, confused, down played and then moved on.
That over unity device you enquired about is @
https://overunity.com/19272/more-clairifaction-of-floors-twist-drive/msg571683/#msg571683
Do you not have the time, or are willing to discuss that device right here ?
ramset
Previous Reply to Willy
Maybe reboot topic or ?
Example Build info ..spec sheet etc
So others can help advance ?
End quote
Willy
Sorry if you feel my above request was insincere?
Could not be further from the truth!
Unfortunately I have very little time ATM
Absolutely inundated with open source FE work ATM
And the rest of life's responsibilities!
Respectfully
Chet K
Ps
Your link again
:Edited for spelling error
Thanks Grandma
