AC voltage from single magnetic pole
Started by nix85, October 04, 2020, 10:16:36 PM
citfta
Quote from: nix85 on October 10, 2020, 09:26:26 AM
If you're getting cataract surgery, astaxanthin is a must, in fact, it's a must in any case.
Get natural not synthetic.
Thanks for the suggestion.  I did check the eye health complex multivitamin I am taking and that ingredient is in there.  I also looked it up and it appears to be another one of the amazing natural sources for good health.  I discovered that curcumin (the extract from turmeric) has some amazing healing powers also.  It completely cleared up the psoriasis on my hands that 2 different dermatologists had tried for 5 years to clear up without any success.  In six weeks the curcumin completely cleared up the psoriasis.
Thanks again,
Carroll
nix85
partzman
OTOH, here is a test done with ferrite cores.  In the layout, two 3019 pot cores with no gap are enclosing a primary coil as a standard configuration.  Then on the outside of each end of this assembly,  an additional 3019 half core is placed with no gap that encloses a secondary coil.  This assembly is clamped together tightly.
So we have one primary and two secondaries that are separated electrically but are connected by the electromagnetic change in permeability in the common ferrite walls between the outside of the primary core and each outer half core containing the secondaries.
One secondary is shorted with a current probe to measure current while the opposite end secondary is connected to a 10k ohm load resister to dampen the self resonance of the secondary inductance with the 3.9pf scope probe capacitance.
In the scope pix we have CH1(yel) is the gate pulse driving the mosfet switch connected to the primary, CH3(pnk) is the output voltage across the 10k load resistor, and CH4(grn) is the shorted secondary current.  As one can see, the voltage and current are in phase.
The primary is purposely driven into moderate saturation to see the resulting effects on the phase.
Regards,
Pm
nix85
Someone bring in Heins, reader will get false impression that current can't be delayed which is utter nonsense.
Message to Heins sent.
Besides in his video i linked in his bi toroid, when he put load to the secondary IV remained 90°  apart.
partzman
Quote from: nix85 on October 10, 2020, 11:05:23 AM
Nix,
OK, I watched the Heins BiT video and his device is a reactive to real power converter with apparent gain.  As has been stated before, this is a transformer assembly with the primary source being considered which is not the criteria that Verpies specified.  Only the secondary or secondaries can be measured for parameters.
I could use one of my reactive to real converters for an example that operates at higher frequencies with infinite OU and input phase angles of 105 degrees but that is not in the true spirit of this discussion.
Experimental evidence is just that and speaks very loudly IMO.  One can simply accept it or replicate it to prove or disprove the evidence.
Regards,
Pm
