AC voltage from single magnetic pole
Started by nix85, October 04, 2020, 10:16:36 PM
nix85
That current starts instantly in high inductance coil at high frequency induced by any means is too far out to accept based on few limited experiments.
Let's bring in someone expert in high inductance, high frequency, sc experts too, let's hear them.
stivep
Quote from: partzman on October 10, 2020, 11:51:18 AM
I could use one of my reactive to real converters for an example that operates at higher frequencies with infinite OU and input phase angles of 105 degrees but that is not in the true spirit of this discussion.
OU doesn't exist, never existed and will never exist or maybe  by OU you understand something else?
Wesley
nix85
I bet if i asked this at yahoo answers, quora and stackexchange, they would all agree that in high inductance high frequency coil there is going to be a delay.
partzman
Quote from: stivep on October 10, 2020, 12:07:11 PM
Wesley
Wesley, you are certainly entitled to your opinion but with all due respect I have to disagree.  Perhaps I should have defined my meaning of "OU" being more output than input and "infinite" meaning more energy is returned to the source than is consumed to produce real energy in a load.
You didn't question the technique used to perform this task but suffice it to say that the device at this point is not possible to build for technical reasons.  If you or anyone else can point the way to synthesizing sinewave frequencies in the 2-4MHz range using class D amplifier techniques so the mosfet switches used can be operated in both their normal forward conduction as well as reverse conduction, then it's a done deal.
The theory behind the gain is from the work of Arie DeGues as is best understood at this point in time.
Regards,
Pm
nix85
Magnet only motors prove OU in most simple and undeniable way. Few real ones on YT.
