AC voltage from single magnetic pole
Started by nix85, October 04, 2020, 10:16:36 PM
stivep
Quote from: partzman on October 10, 2020, 12:47:35 PM
Wesley, you are certainly entitled to your opinion but with all due respect I have to disagree.
Perhaps I should have defined my meaning of "OU" being more output than input and "infinite"
meaning more energy is returned to the source than is consumed to produce real energy in a load.
OU overunity  is usually understand as more  energy
OUT than energy delivered to the device or circuit.
That  will never be possible.
_______________________
https://projectcamelot.org/degeus.html
https://www.americanantigravity.com/arie-degeus-on-fusion-zero-point-energy
Arie DeGues  was in my mind  a victim of   opposers  seeing conflict of interest who started to believe that he has something in his hands  despite  the reality of facts.
The same was with me, and "some" Russians till I explained to  the public that this will not help .. especially  today - in time  of internet even after I'm gone.
______________________________
J
Quoteun 15, 2016 ยท AMDG Scientific Corporation is a research & development company named after its founder and chief scientist,
the late Arie M. DeGeus, who discovered novel energy generating technologies, all of which feature 'over-unity' energy production.
https://peswiki.com/directory:amdg-scientific-corp
here is  mentioned OU that doesn't exist .
Project is dead.
_____________________________________
If you or anyone else can point the way to synthesizing sinewave frequencies in the 2-4MHz range using class D amplifier techniques so
the mosfet switches used can be operated in both their normal forward conduction as well as reverse conduction, then it's a done deal.
The theory behind the gain is from the work of Arie DeGues as is best understood at this point in time.
You feed D  with two signals at the same time  coming from two separate  generators.
In D class amplifier at channel #1  you installing  bandpass filter with bandwith of your desired frequency.
In D class amplifier at channel #2  you installing  bandpass filter with bandwith of your desired frequency.
after that you can do with these  two signals whatever you want. e.g. add,  subtract or take away , multiply,  modulate one with another  and reverse ....and so on.
there is nothing difficult or special about it.
Amplifier  must  be capable of  2 to 4MHz bandwidth at expected linearity.
Mentioned above  applies  to  single mosfet amplifier per channel as well.
https://www.ti.com/lit/ug/tiducz2/tiducz2.pdf?ts=1602350182198&ref_url=https%253A%252F%252Fwww.ti.com%252Ftool%252FTIDA-00733
Wesley
partzman
Yet another test device that may be the closet to meeting Verpies requirements but only he can determine that.
Referring to the pix, the induction source consists of two identically wound primary air coils that are placed back to back or finish to finish as shown.  The finish winding are connected together and the start windings are also connected together with both coils therefore in parallel.  In this connection form, the coils will operate in a bucking mode and in the center where they meet, a compressed unipolar magnetic field will be formed that will start from zero, increase and then return to zero.
This field will induce a voltage and current to a secondary that is positioned directly over the junction of the two primaries at a right angle to the axis of the primaries.  This is the elongated coil seen in the pix.
The scope pix has CH1(yel) as the gate drive pulse, CHR1(wht) is the stored and dampened voltage waveform, and CH4(grn) is the coil current.  Since both are referenced to the same bucking field timing, it is seen that the voltage and current are in phase.
The primary bucking coils operate as follows: Picture both coils placed side by side with coil1 start-finish, coil2 start-finish.  Now rotate coil2 180 degrees so the finish meets with the finish of coil1.  Using the right had rule, now determine the flux directions in both coils if the finish wires are connected and used as the input.
Regards,
Pm
partzman
Wesley,
I will attach the DeGues patent that I feel best describes the operation of the circuit I disclose in the attached pdf.  The requirement to accomplish the MEI function as shown is to have a sampling frequency at least at 4x3MHz and this is far from ideal and in fact may not work.
As can be seen in the paper, the energy reverses each quarter cycle so the sampling must be considerably higher to produce as faithful a sinewave as possible.  This would require sampling frequencies in the 30-60MHz range or higher.
Some might say use DDS technology.  DDS chips operate at low levels when compared to the sine voltage in the MEI.  This means high voltage, high current, high speed devices must be used plus they also be made with a process that allows them to reverse conduct.  Also note the input reactive power required from ~400w-~600w peak to produce ~35w real output.  Whatever is synthesizing the sinewave must be able to handle this reactive energy that is returned to it.
Regards,
Pm
stivep
Quote from: partzman on October 10, 2020, 02:37:35 PM
Wesley,
https://youtu.be/HrAWejpez38?t=867
this concept will not work but in therms of  measurement I agree.
look below:
Wesley
ramset
Thanks Grandma
