Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
bolt
yes the loop collector is balanced with very low impedance and the signals are unbalanced high impedance. The balun also provides a mixer function.
giantkiller
Quote from: BEP on September 17, 2007, 03:33:36 PM
@bolt
Since 'balun' stands for 'balanced/unbalanced' and they are simply transformers made to connect balanced to unblanced loads/sources and match unequal impedances. Do you have an idea which part is balanced and unbalanced?
@GK
Rogue waves are fun - magnetic or otherwise. When you have three meeting to produce the rogue the amount of power and the sound of the tri-tone is amazing but only if each signal is alone on its speaker. Otherwise the same tone is there but there is no body.
I totally understand that. But in the field of a BOSE acoustic radiator is immensely different. This is the most amazing piece of equip I have ever experienced. This is a test before I plug the signals to the turbo coil.
bolt
GK when you tuning up the tpu it would help to leave a tiny bit of audio tapped off through resistor dividers then a cap for safety for DC isolation and fed into your hi fi then you will know when you are in a phase locked situation with time as you learn exactly what the sound is like when favorable. Also if you are eager to press with some testing just make one audio amp then calibrate and test the bandwidth from DC to 500k. Then feed in three sines and try this into your tpu.
Earl
Thaelin,
the image looks to me like a 3:1 unbalanced autotransformer thereby giving an impedance transformation of 9:1.  It is definitely not a balun since there is no BALanced to UNbalanced transformation taking place.
Regards, Earl
Quote from: Thaelin on September 17, 2007, 06:56:52 AM
   @ All:
   Well I just had to go play in Balun land for a while and found a 9 to 1 balun. See the attached photo and see why I jumped out of the chair a bit. Plays with the mind.
thaelin
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
giantkiller
Quote from: bolt on September 17, 2007, 04:01:11 PM
So I could make one out of iron wire as a base and wrap 4 coils on it to what ever combinations I need for a passive configuration
or use a summing opamp as an impedance matching input to output with gain. If I was to stick with active components.
--giantkiller.
