Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 47 Guests are viewing this topic.
Loki67671
All,
I'm winding..............I'm winding...............and working on a precision clock source. You all may want to have a look at the Analog Devices AD9833. They are programmable waveform generators that will allow you to generate sinusoidal/triangle/square waveforms from 0Hz to 12.5MHz. Place a wideband unity gain op-amp buffer stage inline, next, feeding MOSFET gate driver stages and finally the power MOSFET's themselves, That will allow you to have digital control of the three seperate frequency synth's and allow you to put a little space between you and the DUT (Device Under Test). Actually as much space as you need. I've got my family to look ot for, so I won'tbe firing up in the living room. Has any one looked at or run calculations using the "standard knowledge" ? I would like to see, or perform, some analysis to see where we are in terms of standard theory. It is important to document the experiments so that EM theory can be updated if the results warrent it. Remember that experimental results that contradict accepted theory can mean discovery. Yes, I have a scope, and access to just about anything I'll need. I'm a professional test engineer.
GK................consider the possibility that your blood pressure is up, stress and excitement, and etc but do also play it safe. Standard laboratory safety should be used by all of us. I intend on data logging my TPU experiments and after I get this pig up and running I'll have a look on the spectrum analyzer for anything of interest. The FCC would likely be the agency to get involved first, at least here in the states and I do have an FCC GRTOL so we need to be careful there. I'm probably going to put mine in a hole in the ground as opposed to the Faraday cage as I thought we were talking about interacting with the Earth's magnetic field. Doesn't make sense to me to shield it from the proposed source. Under a significant amount of dirt should do the trick.
Yes I've been watching and reading for a long time...........but I'm also winding and designing my lab setup...................more to follow.
Damn the hydrocarbon fuels.......damn them all. Keep up the good work everyone.  ;D
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
otto
Hello all,
sorry guys I cant be quiet!!
Did you ever ask yourself why we have NO POWER in our coils????
Where is the POWER???
Why cant we make even a 40W light bulb to light????
We feed into our coils 1 or 2 or 3 or even more amperes but nothing. Where is the Power gone???
The answer is in the wave (kick)!!!! You know, a wave (kick) is a very, very powerfull "Thing"!!
Otto
mrd10
@Dave,
that little test from Otto, im confused by the diagram, it looks like the light bulb will light hard on, when you connect it all up.
Incase i missed something please let me know.
Dom
mrd10
Ah yeh i think i did miss something, 12volts aint going to light a 40watt bulb, but whacking it with pulses, which produce kicks might.
did i just answer my own question.....lol
Dom
CTG Labs
Dom,
I dont know what its meant to do.  It will be hard on, but it will also have pulses in it.
Otto has told me that his work so far has all been for shit and it was based on this, its an example of not what do or something.  But he has something major to tell us that he realised from this circuit.
He wants us to try it first and think about it, then he will tell us his news.
D.
