CMOS Oscillator
Started by synchro1, July 03, 2021, 11:30:02 AM
synchro1
The neutralization pulse oscillation is a fiendishly simple solution for the control pulse that Evostar has complex integrated circuitry to control. He is generating 3500 volts with the coupled Mosfets. The large Capacitor lowers it for discharge back into the coil.
synchro1
Look at the position of the body diode between the drain and source of the Mosfets.
synchro1
The sensitivity of the Mosfet gate to ground proximity is many times greater than the best Hall Effect transistor. Connecting both Mosfet gates to the same electrode will insure simultaneous triggering.
I connect the gates to a razor blade by copper magnet wire, position the blade on the face of the factory machined electo magnet, and connect another copper wire from the ground to the ferrite ring I use as the attractor. A field effect triggers the pulse with no physical contact as one can see in my video. The electromagnet has a stack of strong neodymium magnets attached. The ferrite ring is attached to an elastic band.
Half the cycle is free power from the attraction magnets. This by itself delivers a COP of 1. Collecting and recycling the voltage boosted backspike for simultaneous delivery to the Electromagnet coil has to send the even COP overunity!
2 mosfets in series, 3 diodes and a large Capacitor! This can run a compressed air pump and generate excess electrical power as well.
synchro1
Here's a picture of the ferrite ring at triggering distance , the electro magnet and backing neos and the gate electrode. The "Gray Tube" "married hi voltage and amperage for a super magnetic pulse. The simultaneous dielectric discharge is basically the same. This should be the most efficient electric motor ever built.
synchro1
