The MAD MAX e-car
Started by lancaIV, July 23, 2021, 06:56:42 AM
#50 :  https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Vespa
          Past and current types
          https://translate.google.com/translate?sl=auto&tl=en&u=https://de.m.wikipedia.org/wiki/Vespa_125
          ic-engine power 4,5 hp or x 0,745 = 3,35 KW (peak)
        Top speed 70 km / h
         empty weight  83/87 Kg
          Models currently on sale
        Vespa Elettrica electric motor with 4 kW and 200 Nm,  weight 130 Kg
        https://wlassets.vespa.com/wlassets/vespa/master/tech_spec/EU5/ELETTRICA_45_KMH_EU5/original/ELETTRICA_45_KMH_EU5.pdf?1611747684351
                                  CONTINUOUS POWER 3.5 kW
                                  MAXIMUM POWER 4 kW
                                45 km / h top speed,
                                100 km range (200 km with Range Extender (Version X)), multimedia on-board system - from October 2018) [5]
                                         weight,"wattage" or rated electric motor power
#28 :        25 Km/h   top            1,2 KW   MB F-Cell Roadster
                                                 https://en.wikipedia.org/wiki/Mercedes-Benz_F-Cell_Roadster   350 Kg weight
                40 Km/h   top            1,5 KW   12 Volt  weight ? http://www.evalbum.com/314 99 Kg weight
              120 Km/h+ top            1,5 KW   230 Volt/50 Hz conventional gasoline car ( with ic engine 800 Kg+ ) to electric modification
#43 :
                    rated "wattage" and/or electric motor power,weight,speed max.
   https://german.alibaba.com/product-detail/2020-new-model-e-trike-manila-for-sale-62221349480.html?spm=a2700.7724857.normal_offer.d_title.4ff938acb2Sy61    450 US$/95 Kg
            500 W motor                                 speed max 25 Km/h
https://german.alibaba.com/product-detail/battery-operated-electric-cargo-tricycle-with-heavy-loading-500kg-van-tricycle-for-delivery-e-trikes-62149442633.html?spm=a2700.7724857.normal_offer.d_title.6e6c38ac5HBavt750 US$/370 Kg
           1000 W motor                                speed max 28 Km/h
https://german.alibaba.com/product-detail/exuberant-e-trike-for-indian-people-with-great-performance-1600146132970.html?spm=a2700.7724857.normal_offer.d_title.6e6c38ac5HBavt  1750 US$/350 Kg
           800 W motor                                 speed max 35 Km/h
https://german.alibaba.com/product-detail/mobility-closed-m1-trike-m-1-e-car-electricscooters-new-electric-tricycle-1600118965036.html?spm=a2700.7724857.normal_offer.d_title.6e6c38ac5HBavt  1450 US$/155 Kg
          800 Watt motor                             speed max 25 Km/h
#50 :
             https://www.youtube.com/watch?v=ioWv_sePLU0  nominal 350 Watt e-bike/Mo-Fa ,speed max 40 Km/h
            https://www.youtube.com/watch?v=Hf31fQJVWOU   ic to nominal 750 W e-bike,speed max 50 Km/h
            https://www.youtube.com/watch?v=pwX1vGQIwqk 1200 Watt 220 Volt,speed max ?
            https://www.youtube.com/watch?v=L1SWRb_7f48  2000 W nominal , speed max 70 Km/h
Some seems not to understand : electric motor wattage overrating follows
                                                https://www.quantum-controls.co.uk/insights/faqs/what-is-cube-law/
                                                high losts !
A pump or fan ,edit: or wheel, running at half speed consumes only one eighth of the power compared to one running at full speed.
the #50 video e-bike conversion numbers and the " cube law"-performance
when rated 2000 W for speed max 70 Km/h
so                          for speed max 60 Km/h  cube law applied :  [(60/70)x(60/70)x (60/70)] x 2000 W =  rated 1260 Watt
                             for speed max 50 Km/h  cube law applied       50/70    50           50        x 2000 W =  rated   720 Watt
                             for speed max 40                                          40/70                                             = rated    373 Watt
                             for speed max 35 Km/h                                 35/70                                             = rated    250 Watt
                            as 30 Km/h City-limit reference
                            for speed max  30                                          30/70                                             = rated    157 Watt
and now to refind the Gruber motor and Dr.W.Volkrodt 25 Km/h biker e-assistant values
                            for speed max 25                                            25/70                                           = rated      91 Watt
from decelerating step down
to
accelerating : step up "cube law"-performance = invers application
from 25 Km/h to 70 Km/h                                                          [(70/25)x(70/25)x(70/25)] x 91     = rated 1997 Watt
Okay , https://overunity.com/13068/friction-heater-running-in-my-house/msg470504/#msg470504
                                                  heat pump  example
           http://www.fujitsugeneral.co.nz/faq-s#faqnoanchor
           Why is it recently that a single heat pump can heat or cool very large areas?
It takes almost twice as much energy to heat a house from 2 degrees to 20 degrees as from 7 degrees to 20 degrees.
So if you want to make sure you are going to get heating in all situations the heat pump needs to be sized correctly
a. 7 degrees to 20 degrees = 13° K
b. 2 degrees to 20 degrees = 18°K
normally ,wrong calculated : a 20 sqm room ,4 mtr x 5 mtr, with 2,5 mtr high = 65 sqm (without 20 sqm base) room exterior surface
       65 sqm a K-value 1,0 x 13°K =   845 W heat source need
       65 sqm a K-value 1,0 x 18°K = 1170 W heat source need
                                                     1170/845 = 1,384
      cube law effect           18/13 = 1,384 v3 = 2,65
https://www.fenixgroup.cz/de here the above " Fujitsu hypo-/thesis" confirmed !
the "cube law " also called https://en.wikipedia.org/wiki/Affinity_laws
I think it will be time to research the "Relativistische Kinematik/relativistic kinematics  https://en.wikipedia.org/wiki/Relativistic_mechanics    "
relationship between the "Affinity laws (proprotional/square/cube)" effect
and under "Schroedinger electron-gas"-condition as Bionik-theme the Biot-Savart law analogy !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19850314&CC=DE&NR=3330899A1&KC=A1
https://paxscientific.com/   https://paxscientific.com/flair  https://paxscientific.com/innovative-technology   https://paxscientific.com/flow
btw : the Fritzsche ic-engine hibrid concept,instead ic-engine the 90% di Pietro air engine ? + improved generator couple and Ferreira motor
When actually ic-engine power-to-wheel efficiency is in the     <10% range ,
by Fritzsche with conventional engine/conventional generator <20% range
                         di Pietro engine/conventional generator conversion  45% power-to-wheel efficiency range
                  with di Pietro          /   improved   generator                   90% power-to-wheel efficiency range
and by Ferreira motor use  90% di Pietro engine as propulsion source less " compressed air storage " need
https://treasury.gov.au/sites/default/files/2019-03/R2011-002_Engineair.pdf
There are no toxic chemicals used as for batteries, the running life is considerably greater than for throw away battery packs for vehicles. Our ranges are similar but our recharge time is a few minutes rather than hours.
Our run times can be increased by using some form of heat store to boost compressed air pressures -
this can be through on-board solar thermal sources for example.
What makes these applications so viable is that the Di Pietro motor has been very cleverly designed
to use far less air compared with other current air motors -
our current 9 chamber motor uses nearly 4 times less air than its competitors for the same power output -
so far less running of power hungry compressors.
Additionally outlay on large capacity compressors can be much less in industrial situations.
We have to work inter-disciplinary/inter-facultativ and inter-national to get the best result !
Thermoscience : Bionics and Geonics(Space-Time: Volumetrics)
Classical laws,up to declared :Axiom,probably with fixed constants(Avogrado,Planck et et cetera) and newest findings/corrections !
International Prize participants entree and winner scientifical results !
Thermoscience and Thermoengineering :
Gay-Lussac
Avogrado
Michel Rodriguez
Michel Prueitt M.E.C.H.
Wilhelm Haeberle
Pax Scientific
an internal combustion (differs from external combustion ?) engine seen as "heat canon" ( Paris "1,5°C temperature increase limit ")
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Hei%25C3%259Fluftgebl%25C3%25A4se
1 litre water as liquid transforms to ? litres hho-gas ? 1000x+ volume expansion or gas-to-liquid compression
with expansion volume the temperature a. increase b.decrease cases !
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=19740299&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
The asymmetrical cycle of this process for converting thermal energy into usable mechanical energy, shown in the Mollier t / s diagram for carbon dioxide (CO2) in Fig. 1 and Fig. 2, works on the left side of the inversion line, in a pressure range in which all processes run mirror-inverted to the right-hand side of the inversion line and the usual behavior of CO2 is reversed:
When the pressure increases, it cools down instead of warming up.
When the pressure drops, it is heated instead of cooled.
According to Maxwell (1831 to 1879) and Boltzmann (1844 to 1916), all molecules are constantly in motion, that is their natural state.
They either fly through space (gases) or swarm closely together (liquids), or they oscillate quickly around a central position (solid), and they can also vibrate and rotate and perform combinations of all of these movements.
The movement increases with increasing temperature and decreases with decreasing temperature.
With increasing pressure, the packing density of the molecules rises in liquids, they mutually hinder each other's freedom of movement.
The vibrations become smaller in spite of the work expended on the compression and smaller vibrations mean a temperature and thus a decrease in entropy.
With decreasing pressure, the oscillations of the molecules increase again, the temperature and the entropy increase. ... ."
ambient air temperature intake to engine / acceleration (Rodriguez : gigacycles)/ combustion process temperature engine outtake/exhaust
https://www.sciencedirect.com/topics/engineering/exhaust-gas
2.2 Engine specification and exhaust gas composition
Item
Data
Exhaust gas temperature 365 °C
Before turbine temperature 342 °C
After turbine temperature 193 °C
https://www.researchgate.net/post/What_is_the_influence_of_engine_load_on_the_exhaust_temperature_of_an_IC_engine#:~:text=Temperature%20of%20engine%20exhaust%20is,can%20destroy%20the%20catalytic%20converter.
                                                     300°C - 700°C exhaust temperature !
                 hydrogen internal combustion process exhaust temperature ? (BMW hydrogen-Otto-cycle !)
         https://www.researchgate.net/figure/Exhaust-gas-temperature-of-gasoline-and-hydrogen-engine-Figure-76Portrays-the-NO-x_fig9_310772006
ambient temperature air to engine as engine exhaust to ambient air : ambient air volume temperature change after engine exhaust ?
6 Litre liquid/100 Km gasoline to 5,1 Kg gasoline consume + 1:14,7 (total 15,7 units) ambient air mix = 80 Kg/ 100 Km gas mass consume
                                      80 Kg gas mass its volume ? Its average temperature as exhaust ?
                                                         "After turbine temperature 193°C " ?
                                    combustion process  (heat canon like) before/after exchange
                                                        ambient air unit/-s            exhaust unit
simple calculation example  :o       :   1 gas mole unit a 20°C  + 1 gas mole unit a 30°C     =  2 units with average 25°C
                                                        1 gas mole unit a 20°C + 1 gas mole unit a 193°C   = 2 units with average 106.5°C
                                                        9 gas mole units a 20°C + 1 gas mole unit a 193°C  = 10 units with average 37,3°C
                                                       99 gas mole units a 20°C + 1 gas mole unit a 193°C = 100 units with average 21,73°C
                                                      80 Kg exhaust air mass a 193°C temperature x 100 = 8000 Kg ambient air mass with 1,73°C increase
air density(clearly temperature/humidity/pressure et cetera dependent,average https://en.wikipedia.org/wiki/Density_of_air
        At 20 °C and 101.325 kPa, dry air has a density of 1.2041 kg/m3.
                                                 8000 Kg/1,2 Kg = 6666 cbm or as gas volume : 6 666 000 lt. (per driving unit ! )
                                                         with "only 193°C exhaust temperature" calculation !
                                                       6 666 cbm / 3 metres high = 2222 sqm area 1,73°C temperature increase
                                                      1 sqKm = 1 000 000 sqm /2222 sqm = 350 ic-engine vehicles a 6 Lt fuel/100 km consume per sqKm
                                                        6 Lt. +X per  a.100 Km or  b. per hour     consume ? ,
                                                 space temperature increasing tipo - "heat canon" on 3/4-wheels -  in action ?
              A fuel-kind change does not change ambiental temperature increase by same/similar high process exhaust temperature
for clearance : this as car use time effect /24 hours  https://www.nationmaster.com/country-info/stats/Transport/Vehicle-abundance
but related total transportation sector  https://www.maritime-executive.com/article/transport-uses-25-percent-of-world-energy
passengers =  as light-duty vehicles 45 q. BTU  from 55 quadrillion BTU representing
2019 total primary energy consume : https://en.wikipedia.org/wiki/World_energy_supply_and_consumption 14420 Mtoe 2018
14420 x 11,63 TWh or    14420 x (11,63 x 10v9 KWh)   1 KWh = 3410 BTU
14420 x 11,63 x 1 000 000 000 x 3410 BTU
= 571 872 686 000 000 000 BTU
0r 571,87 quadrillion BTU global total energy consumption ,
Related 24/365 solar radiation in BTU ? 82 million quads of BTU,for free ! 1 quad = 1 quadrllion BTU
Or solar radiation to planet Earth per year : 82 000/571,87 times the human statistical  energy consume
                                                            = 143,4 times
Upps, :-[ :-\ :'( ,Pardon-me,a calculation error above to see :
                                       82 000 000 (quads)/ 571,87 ( quads)  = 143 390 times
                          I am not perfect,I am human ! With the right/ obligation to correct !
8% passengers light-duty vehicle transport/traffic part
https://www.lawinsider.com/dictionary/light-duty-vehicles
https://www.eia.gov/outlooks/ieo/pdf/transportation.pdf  BTU consume for 2040 preview : increase !
so we can remark that total passengers transport as  light-duty vehicle only participate with actually 8% by the caloric climate change !
Only use/driving(air conditioning/heating/cooling),not vehicle production included !
Even 8% to 4% halfing  = 96 % other energy consumption climate change sources will stay ,by growing world-population
        8% to 0,8% decimation = 92,2 % other climate change sources will stay !
10 billions human habitants with only 25% G7 actually material/energy habitant consume as social comfort demand : ? Earth in number !
Am I un-fair in my treating from member Ufopolitics ?
https://overunity.com/15864/friedrich-luling-magnet-motor/msg560343/#new
" This Lüling Motor research and development is not to start "commercializing it" !!"
commercializing : offen zu Markte tragen, openly presenting
         NOT ?                       AFFRONT !
He can apply for the "Overunity Prize",no doubt,I invite him !
But it is not the real "overunity.com-forum philosophy" target !
( Probably for some : " dem Establishment ans Bein pinkeln/ pee on the leg of the establishment "-Aktion )
My personal opinion,can be wrong !
The first target he would reach ,#60 : a cold process motor principle !
First success !
since vapor-driven (unmanned) mobile
https://en.wikipedia.org/wiki/Ferdinand_Verbiest                             1672
vapor-engine driven 3/4-wheel passenger mobiles
https://en.wikipedia.org/wiki/Nicolas-Joseph_Cugnot                        1769        2019 : 250 YEARS AUTOMOBILE JUBILEE !
https://en.wikipedia.org/wiki/Richard_Trevithick                               1801
https://en.wikipedia.org/wiki/Nicolas_L%C3%A9onard_Sadi_Carnot  1824
https://en.wikipedia.org/wiki/Bertha_Benz                                       1888
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870512&CC=US&NR=4663939A&KC=A
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=8&ND=3&adjacent=true&locale=en_EP&FT=D&date=19970506&CC=US&NR=5626459A&KC=A
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920428&CC=US&NR=5107682A&KC=A
https://en.wikipedia.org/wiki/Mercedes-Benz_F-Cell_Roadster   1,2 KW e-motor Voltage ? DC or AC ?
https://web.archive.org/web/20160303222913/http://www.benevelli.it/files/Mercedes_Benz_Fuel_Cell_Project.pdf
https://patents.google.com/patent/DE10011074A1/de              1,5 KW 220 AC Volt
F-Cell :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19280203&CC=FR&NR=633752A&KC=A
Un exemple :
il est avéré qu'un minuscule récipient cubique de o- 3o (le côté, d'un poils moyen de 15 kilogs, en pleine charge,
contient 55o éléments complets dont voici la puissance électromotrice Tension : 66o volts.
Intensité : 1,5 ampères pour une. Résistance intérieure : de 44o ohms. force qui ne se dégradant que de i !à volts par heure,
laisse une marge de force utile lar gement suffisante pour entraîner un moteur de 1o HP à 15oo tours,
durant 3o heures au minimum, force à peu près gratuite et renouvelable à tout instant par une simple réimbibition des sachets de charbon (opérable en quelques minutes).
660 V x 1,5 A = 990 VA
1 hp (french)=   735 W
10 hp  ergo  = 7350 W
how did in this time ,20s from last century,the engineers measured and "rated"electric engine power ,by continuous or peak power !?
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=FR&NR=633752A&KC=A&FT=D&ND=3&date=19280203&DB=EPODOC&locale=en_EP
in the "original document" : yes,there - second page  -left side-   line 33-    to read  " 10 HP "
Much experimental freedom from RC-model to ECO-Marathon size vehicles to "conventional compact class car" development !
                                                   with human driver to virtual driver="autonomous"
                                     Yearly regional,national ECO-games to international ECO-games , development "Marathon"
                                     schools and universities : https://www.jugend-forscht.de/information-in-english.html
                                                           senior (elders = U60 e-/in- ducation) universities ,too
                                                          VOLKSHOCHSCHULE
(Volk = Folk and Hochschule = University,to differ : High/Hoch-school/Schule= Oberschule: class 5-12/13)
        Basic/Grund-school/Schule :                     class 1-4
or automatic translated https://de-m-wikipedia-org.translate.goog/wiki/Volkshochschule?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem,se
                                               MADE IN ...... ::)
The Danish folk high school of Grundtvig style also had a lasting influence on the development of adult education centers in Germany .
  Nikolai Frederik Severin Grundtvig is considered to be the founder of the first (home) adult education center in 1844.
  edit : influence probably https://en.wikipedia.org/wiki/S%C3%B8ren_Kierkegaard
  Germany : https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Adolph_Kolping
                   https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Ernst_Abbe
                   https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Max_Weber
Today adult education is understood as an organized form of lifelong learning .
Adult education centers make a contribution to realizing the right to education and equal opportunities .
They derive their educational mandate from the principles of enlightenment and human rights . [3]
        :o  illuminati ? ;)
The global social changes show the importance to be attached to adult education centers in the future.
Some ideas of the original community colleges can be found today in the concepts of national universities .
24/365 open door  on-line community colleges/local house(Gemeindehouse ~ church/Kirche/Tempel/Academia)
                                                              " Volkshaus "
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Volkshaus_Jena
https://www-bpb-de.translate.goog/apuz/26319/dritter-weg-und-kommunitarismus?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem
human rights
to human rights watch
to human rights and obligations watch
24/365
applied social liberalism
Yes,We can     or     Ja,Wir schaffen das
Die Welt auf der Suche nach "Seelen-Heil" ::)
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.bibelwerk.at/dl/NNOrJmoJMLlJqx4KJKJmMJkLMk/Hilf_Herr.pdf
https://www.youtube.com/watch?v=ERYY8GJ-i0I
God-Estate or Estate by God !? socius/social with Ablativ-casus and Kants categoric Vocativ/Imperativ
                                            X = individuals inner voice/line  followed ' tit for tat'
                                                   Nature laws and Bioanalytics
                  caminho a/o  Sao Tome ( Archipel) or Dominikaner St.T. de Aquin : 'fair return' and Jesaja 32,17
            Duke University 75 Watt mobility / VW and other 172 000 W,continuous ? peak ?, power potential
                                  ...., ich will Spass/Fun,ich geb ( electrons/ions) gas,.....
                    solange es die (virtuelle) ECB-chase/case/caixa/Kasse, und deren Glaeubiger, noch erlaubt
US-F.E.D.- return program to Silver-Standart -Dollar, ECB : Silver-Standart-Euro !?
Actual capital uncovered Dollar and Euro nominal value cut ,old/new Dollars and old/new Euros ratio ? Top secret  ;)
European Banking( BG)  and Industry(IG) Union ( or Fusion ),
not only supervisory,but also ownership
V.olks E.igener B.etrieb  in G.D.R. ,here now ECB-E.B. ,commercial,financial,industrial
                                                  in U.S      F.E.D.-O.-E.  Owned Entity
the ECB first Frankfurt-headquarter : IG-(FARBEN)HAUS
IG-FARBEN ( Farbwerke Hoechst,BAYER,B.A.S.F. and +)
Lieferant des nicht A,nicht C,sondern als besonders human ausersehenen Gas-Gemisches des Zyklon B
DR-Kanzler und DR-Fuehrer A.Hitler,so ist es zu lesen,befahl :
( so weit wie moeglich) schmerzlosen Tod/Liquidierung  !
communitarism :    Unser Reich komme,UNSER Wille geschehe
Dschihad catolico  ;D WELTENREICH,so weit wie moeglich  8)
                                          ICH habe SPASS
Hiro-Shima,die steinerne Treppenstufe,ehemals ein Mensch darauf,vor atomaren Schlag,nun ein "ewiger Schatten"
https://de.wikipedia.org/wiki/Engelmacher
(Nielsen) Passanten-Frequenz
https://www.youtube.com/watch?v=c2f29bKVNMQ
units passage per volume  https://telefonzelle.de.tl/Telefonh.ae.uschen-TelH-78.htm   volume = 2,3 cbm
Chamber
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940707&CC=DE&NR=4312372A1&KC=A1
Engel-Kammer (Plasma converter)
and/or
https://www-n--tv-de.translate.goog/wissen/Corona-Pandemie-folgt-altem-Naturprinzip-article22786704.html?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem
Dem Ersten (kill the winner) immer Vortritt erlauben  ;D
research and science without limits !
https://www.bu.edu/wcp/Papers/Scie/ScieGher.htm#:~:text=form%20of%20Science.-,Does%20Empirical%20Science%20have%20any%20limits%3F,unresolvable%20questions%2C%20they%20have%20sense.&text=It%20is%20shown%20not%20only,we%20have%20about%20the%20world.
Does Empirical Science have any limits?
The answer of the scientists is No: Science is unlimited.
There are no scientifically unresolvable questions, they have sense.
The answer of the philosophers is not clear, but it is close to No.
It is shown not only in technology, and philosophers also claim, that Science is the best knowledge we have about the world.
It seems clear, that Science will never reach an end.
                                                               Sado-/Maso relation
        Master and servant
        Servant and master
                                                      science = visiting heaven and hell
                                                no questions anymore,100% satisfaction
        Todesengel
                                             https://deutsch.radio.cz/mengeles-zwilling-a-782-8109581
                                             https://deutsch-radio-cz.translate.goog/mengeles-zwilling-a-782-8109581?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem
https://sites.google.com/nxj.quererla.com/lopevobox01/epubpdf-download-mengele-the-complete-story-by-gerald-posner-book
                                                      and to let not "shadow"-print behind
the world has to ways : ordered communitarism or
        a. DAESH/IS  Raqqa-like anarchism (open concentration-camp)
        https://theglobalcoalition.org/en/timeline-fall-daesh-raqqa/
        b. youth estate-in the-estate like
        https://de.wikipedia.org/wiki/Mara_Salvatrucha
        https://en.wikipedia.org/wiki/MS-13
                                               https://en.wikipedia.org/wiki/Mad_Max_(film)
        justice ?
        face-by-face
                                        or by remote controle/autonomous objects  ,the vengeance/retribution
                                              the individual decision case : subordination or suicide
                                                        best/worst case preview and plannings
Dystopia
https://de-m-wikipedia-org.translate.goog/wiki/Fahrenheit_451?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem,se
           how much reality the next generations have to receive by education ?
                   the "actually termed " social classes upper 50/lower 50
