Maybe some NEW info?
Started by Johan_1955, November 12, 2021, 07:03:06 AM
sm0ky2
From all possible tests
This is where my understanding is going:
https://youtu.be/-LEdjNVYJl8
sm0ky2
Increased the power 3x
Up to 0.052 Lumens produced by my 0 Watt light bulb
https://youtu.be/PbvkdtR1CgA
sm0ky2
When i try to use this value of 0.052 Lumens
to reverse engineer the circuit
What i come up with is something in the milliwatt range
to cause these led's to produce this value of light
This is not a large amount of power
It is however, 233.4 x greater than the abilities of my 2-wire earth battery
(made using the same anode and the center pin of the coax as the cathode)
electrically speaking, this is an open circuit
that's why i had to use the light output to reverse engineer the power
and no, theres no readings on the back-loop either
sm0ky2
In an attempt to balance the load between the 2 diode chains
I replaced the reverse loop with a close match
https://youtu.be/hM3nC_5XxF0
And then replaced the first set with a duplicate
So they are truly identical now (within reasonable measurement)
3-diodes in series
2 chains in parallel, one going the other way.
Or if you prefer: 6 series diodes, fold in half and twist the ends
Taps are between the twisted end and the center fold
One end to earth, the other to an ion source
https://youtu.be/qWLq58OymgA
Final Luminosity reading: 0.4785 Lumens
And for those interested, it does charge electrolytic capacitors
in various configurations, just as presented by the Inventor
The generous Nigel 'Hands' Cheese or whatever he calls himself.
sm0ky2
Had to try one last thing before i head to St Louis for the weekend
I hooked up a 2nd wire to the same earth ground and another 6-diode loop
to the same ion source
And those also light up
So im up to pretty much 1 Lumen
