Maybe some NEW info?
Started by Johan_1955, November 12, 2021, 07:03:06 AM
Floor
https://www.answers.com/Q/How_many_lumen_are_in_1_Joule
683 Lumen = 1 Joule per Second
1 Lumen = 1/683 Joule per Second  or approximately 0.001567 joule per second
1 joule per second = 1 watt
other conversion software sites give the conversion as
0.01 watt per lumen ?
Floor
What ever the output (large or small)...
If "conventional" inputs have been eliminated as a source ...
You have some thing here...
Joule thief "had to be" rewired to make sense in a conventional way.
I have always suspected that, that was its ruination.
Please keep expoloring this smOKy2 and keep us posted
  best wishes
             floor
sm0ky2
Quote from: Floor on November 25, 2021, 12:35:16 PM
Not sure the accuracy of that site.
Here are my experimental results: (using 13 lumen flames)
13 Lumens (through photovoltaic conversion) provides
0.4V @ 205ma
or about 80mW/s
0.01 seems pretty close
Now: solar panel can only convert some % of the energy of the photons
So the real experimental value is much higher.
Also - my Lumens were measured by CandlePower as was performed in the old days
many new experiments use some LED-based Lumen equivalent.
Real flame having more fluctuations, and a higher photon energy density
I confirmed this research by testing 30 Lumen flames and 30 Lumen flashlights
Flames give about 20-30% more current at ~ the same voltage
LED's provide a more consistent light source
I have brought a duplicate circuit with me to St Louis, i will be testing this location soon
To see if the conditions can be recreated here 1000+ miles away.
MasterPlaster
Quote from: sm0ky2 on November 26, 2021, 06:18:34 PM
That is taking it a bit too far!
sm0ky2
Nigel showed us this works in Croatia,
I have replicated it in Texas,
And now also St. Louis
Its' probably safe to say this will work anywhere
https://youtube.com/shorts/GVCuRSlmIps?feature=share
