Maybe some NEW info?
Started by Johan_1955, November 12, 2021, 07:03:06 AM
sm0ky2
Got it working now with only 1 ground wire input last night.
The 2nd ground has been disconnected
led's are still lit after 15+ hrs
Now i have added the other half of the EB circuit in series
Input reads 0.3v
Output 0.3v
LED's got a touch brighter
Current between the EB and the + of the JT: 0.05ma
Current from ground to JT: 0 when EB disconnected (led's still lit)
                                       0.05ma with EB connected (slight brightening)
I unsoldered/resoldered the (dead) battery just to eliminate that as a current source
i unsoldered/resoldered the JT coil to see if that had any current, still 0, and led's lit
with or without the inductor/coil. (removing the ferrite does nothing as well)
So....
We have open + terminal in parallel with a resistor to base
We have an earth ground
We have 3 diodes across the c-e
and a piece of copper wire center-tapped to the 2nd diode junction (heading + to -) also open
3 LED's producing light
We can add the other half of the EB into the +
and get more light (seems arbitrary and distracting)
What's the next step
[edit:] apparently i can choose either ground terminals
of the earth battery. (- to - of the JT or + to +)
The + wire seems to produce a tad more light.
So im using that one now.
Still 0 current reading from ground to JT
(but it will light the LED's through the meter)
sm0ky2
LED still lit,
I am still not able to determine any information on the circuit.
For all intensive purposes, its an open circuit from Earth to an alligator clip
I'm shelfing this one, labeled it " 0-Watt Lightbulb",
Gives my shelf an eerie green at night.
Not sure about the "ion accelerator",
I cant tell that it does anything, from the EB or even a battery
Anyone that wants to give that a go, plz share your results
Now onto the magnets!!!
So, first up appears to be a modified HJ track
However, instead of a single magnet perpendicular
We have a track of sequential parallel magnets
And the rotor has 4 magnets across it's length
     NNNNNNNNNNNNN
     SSSSSSSSSSSSSS
            N=S
            S=N
But ...... they're at 45-degrees
Sooooooo....
I guess theres only one way to know
ramset
For Johan and all
http://www.rgenergy.com/
Shared by AllCanadian
Glad to see you around Johan !!
Respectfully
Chet K
Ps
Sorry to interrupt SmOkey
I looked for topic ( Johan had shared ideas on Papp and water fuel
However it must have been in unrelated sections
Thanks Grandma
sm0ky2
While im constructing the magnetic set-up,
I saw this:
https://youtu.be/3yogEJOJWbQ
And went back to examine the 1-wire circuit.
It only works with something tied to the first diode (+ terminal)
By something i mean i have tried a 6-in alligator clip, a piece of wire,
my finger, a large chunk on various types of metals
Whatever this is ('ion energy', or atmospheric energy, or some weird reverse rectifying antenna)
It needs an electron source. I find copper connected to steel amplifies it the best
there may be better things to try.
I have a 1-meter set of 8 insulated copper wires
8-guage, and wires in parallel at both ends.
Manipulating the laws of parallel resistance, that 1-meter cable
has the Ohmic resistance of 1/8th of the manufactures rating for
a single 1-meter length of this wire.
This works to give more light than a single piece as well
something larger, like a metal kitchen rack brightens it even more
Electrical theory has no applications as there are no readings to take
I have eliminated various causes such as bi-metal by using a rod of twisted diode legs
(from same type diodes i had broken the legs off)
it works in complete darkness
it works inside a faraday cage
It works using a faraday cage as an electron/ion source
Cant seem to shield it at all
I'm ordering a large shipment of diodes, from china.
It will take a bit to get here, but is economical.
I'll follow Nigel's lead as best i can and see how far i can take this
Dansway
Is there a schematic (info) on this tech that you can share?
Thanks.
