RESSURECTED TINMAN NEW INVENTION.
Started by seychelles, December 18, 2021, 10:54:04 AM
seychelles
GREAT WORK CAPTAIN. THANK YOU FOR SHARING.
Jimboot
I found having the TP as close to the EM as possible and the PM about 3mm distance worked best FWIW. Nice documenting Cap.
tinman
Hi Everyone.
I apologize for my long absence.
Well as you have guessed now, I am making this motor public, as I now have in place all the things needed to insure that this does end up in the public domain, and also protections toward my rights as the designer, in that no company or entity can take it, patent it, and shelve it/hide it.
Watching my own videos, I can see that I could have done a much better job at going through the design and workings of this motor.
But as the video's were made for a group already quite versed in it's workings, I left the videos as they were.
In regards to the other private group, and my reason for leaving that group/forum, well there was more than one reason at play.
I myself do feel bad for leaving, and I know the guys over there are also disappointed in me as well, and for that I am sorry.
But as i said, there were many reasons for leaving, and not just 1.
1- one of my children needed my complete attention and time. I won't go into details, but for those that knew what the late Ernie went through with one of his children, then you know what I had to deal with. Thankfully, for now, that child is on the mend.
2- Now don't get me wrong here, the guys in that group were doing what they thought to be the best. But as we have seen many times, most started to stray from the precise design of the motor, and could not achieve the desired results. The 1 person that did stick to the design very closely was Jimboot. He was also the only one that started getting close to the desired outcome. Variations started coming out before the original was even achieved, regardless of my efforts to try and keep it on track.
3- As some of you may know, I own my own business, and when this covid bullshit fest hit, my work load went through the roof-oddly enough. The reason i did so well while other collapsed, is because of my particular line of work, which is fitting lithium off grid systems to caravans and mobile homes ( I think my American friends call them trailers and RVs). So rather than being locked down at home, by our idiotic government and premiers, many decided to go free camping along the coast of Western Australia, and avoid all the drama taking place in the cities and major towns. But in order to do that, you need to be off grid capable. So that is why my work load went up, and many other companies went bust.
4- At the other forum, we started to see a form of censorship taking place, where threads were being closed down due to members having a difference of opinion. There were strong opinions, but it never got to the stage of full on fighting like we have seen here on this forum--but the threads were closed down anyway, regardless of whether or not those in those threads wanted it to continue on or not.
The one thing i will never tolerate is being silenced for my beliefs-like i will not be silenced from disclosing this motor. And this time i have put in measures to make sure that does not happen-again.
Anyway, over the course of the next month or two, I will be redoing my videos that will explain exactly how this motor works, as well as showing you how to build it. So feel free to copy all my videos, and share the links here if you wish.
(CAVEAT--> I cannot and will not guarantee you will succeed at achieving a self runner, as I cannot insure that anyone will stick to my strict build instructions.)
Over the past months, I have been trying to come up with a very simple base- a simple way to build this motor, so as all can achieve there goal, and i have found a way to do it. What you will need is an old broken down brush cutter that has the geared angle drive head- like one pictured here on ebay--> tinyurl.com/2p9fz728 . Or see pic below.
You will also need either the 3/4/5/or 6 blade steel brush cutting disk to go with it--see second pic below
This will give you your torque plates, flywheel, and a means to couple up your small generator via the input of the right angle drive of the gear box, which will become the output shaft that drives your AD/DC generator. This is the simplest and cheapest way i could think of for building this motor.
But this must be done bit by bit, so as we all understand how it works, why it works, and give you your best chance at achieving a self running motor-with power to spare. The more precise you make your build, the better the chance of achieving your goal.
There are some critical tolerances that !must! be had in this build. 1/2 of a mm can make a 100% difference in performance, and this we will see in the coming videos.
The first video i will make will be all about the coil/coils-depending on how many you wish to have.
I will tell you now that you need only 1 to succeed.
The coil is one of the most important components of this motor, and must be built right.
You are going to need to forget about what you have learned about inductance and resistance when it comes to building this coil, as this motor works like no other, and present day inductance and resistance theory does not apply with this motor, which is why we can achieve what is though to be impossible. I will tell you now, regardless of whether you choose to believe it or not--a higher resistance coil is much more efficient that a coil with a lower resistance. Most will think that a coil with higher resistance will be less efficient due to higher resistive losses, but that simply is not true, and when you see what happens in this motors workings, you will understand why.
I will post that video here when it is done, which should be by friday night-my time.
Brad
seychelles
WELCOME BACK TINMAN. I SEE A NEW BRILLIANT APPROACH TO YOUR INVENTION.
LOOKING FORWARD TO FRIDAY UTUBE. SORRY, I AM JUST AN ARMCHAIR SPECTATOR.
BUT BELIEVE YOU ME I AM IN SPIRIT WITH ALL YOUR GREAT ENDEAVOURS.
